Drag Radial Tire Size? - TCCoA Forums
post #1 of 39 (permalink) Old 09-29-2013, 07:52 AM Thread Starter
CometGSR's Avatar
I am going to be getting a set of drag radials to attempt to solve my 60FT times. I would like to go 15x6 size, if possible. Is this a doable thing? I am having trouble finding out what sizes would work or even where to get them. I figured going 15" would cut the cost down in both the tire and the wheels.
I would go with real drag tires, but it isn't practical because I usually go to the track alone and don't have a truck to haul tires around.
Could someone steer me in the right direction?
Thanks in advance!
-=James
1995 Ford Thunderbird V8
SCT Tuned by Amercian Motorsport, Mustang PBR, FRPP 3.73 gears, Modified Trak-Lok, Steeda UDP, K&N Panel, 1990 SC Seats, 2.5" Single Exhaust/Magnaflow Hi-Flow Cats, Michelin Pilot Sport A/S +, Windstar wheels, RichardM Intake, Kenwood KDC-HD552U HD Radio, 2800 stall DirtyDog Marauder TC, J-MOD, 2002 Grand Marquis transmission, DynoTech Driveshaft, AeroForce Interceptor Scan Gauge, Griffin Super High Capacity Radiator, 180* Thermostat, Cobra steering wheel, 6000K HID, Clear Corners Getting a makeover Spring 2015
http://www.fordthunderbird.net - For Pics and more!
CometGSR is offline
post #2 of 39 (permalink) Old 09-29-2013, 08:02 AM
James just to let you know that when my bird first got the upgrades I was running BFG Drag radials on 15x7 and they hooked great with the mods then. Still have them need to burn them down one day
post #3 of 39 (permalink) Old 09-29-2013, 08:44 AM Thread Starter
CometGSR's Avatar
Thanks! I finally found where the drag radial stuff is on Tirerack. It looks like they only have P205/50R15s for 15" that will fit a 6" rim. It looks like I would have to go with a 6.5" rim to get P235/60R15. Of course, there are always 16" sizes.
I was trying to stay with Ford Steel rims if I could help it. I don't think Ford ever made a 6.5" steel rim in our bolt pattern.
-=James
CometGSR is offline
post #4 of 39 (permalink) Old 09-29-2013, 12:31 PM Thread Starter
CometGSR's Avatar
After looking at our options (there aren't many in our size). It looks like the BFGoodrich G-Force T/A Radial 2 is the best choice. It comes in 235/60R15 , which is the closest I found to the original size. They just don't have our cars in mind for these.
The only 15 6.5" rim I found was from a Windstar aluminum. They are cheap and plentiful but it won't win awards in the looks department.
-=James
CometGSR is offline
post #5 of 39 (permalink) Old 09-29-2013, 01:39 PM
MA Drag Race Team Coordinator
1MTNCAT's Avatar
A stock 15 X 6 0r 15 X 6.5 Bird or Cougar wheel will work with any 15" tire up to around a 255-60-15 drag radial. They were a little tight but for a few years I even ran 275-60-15's on mine back many years ago!! They are big 28" tall, 9.5 wide approximately.
The 235-60-15 BFG's are a little on the smaller than stock size but on a basically stock car with just a couple bolt on's will work fine (Little more gear with shorter tire). There are other drag radial manufacturers out there now with tires in similiar sizes and up so look around.
Hoosier QTP also makes a street/strip tire nearly track only that works well if you are close and running back and forth to the strip. a 26" by 8 biased ply works excellent.
Regardless, you need those to pull decent 60's with gear and converter in an MN12 to get decent ET.
Steve
Nitrous 11.75 @ 114 MPH
1MTNCAT is offline
post #6 of 39 (permalink) Old 09-29-2013, 01:48 PM Thread Starter
CometGSR's Avatar
I have the gear and the converter, just need the tire to pull it all together. I looked at other slips I have since I put in the 02 4R70W with the 2800 stall converter and I am spending a lot of time spinning wheels at the line. I think the drag radials will fix that.
-=James
CometGSR is offline
post #7 of 39 (permalink) Old 09-29-2013, 01:55 PM
1MTNCAT's Avatar
It will and I can guarantee you are losing ET on the 1-2 and maybe also the 2-3 shift.
Once you get the tires dialed in all that will go away and you should see significant differences in ET.
People just don't realize.
Good luck with it!! You have good fall air coming as well.
Steve
1MTNCAT is offline
post #8 of 39 (permalink) Old 09-29-2013, 06:20 PM Thread Starter
CometGSR's Avatar
Here is another option. P255/50R16 mounted on Lincoln LS temp spares (16x7) may be a good option. I just have to figure out if I want the Toyo Proxes TQ or the BFGoodRich T/A 2. It might be a bit of a challenge to find the LS spares but I have all winter to do it.
-=James
CometGSR is offline
post #9 of 39 (permalink) Old 09-29-2013, 07:28 PM
rbohm's Avatar
good info here. remember that you are going to want to run lower tire pressures anyway at the track, so a slightly narrower rim isnt going to hamper performance at the track. where it will cause issue is going to a from the track and those are going to be cornering issues that you just need to be aware of.
rbohm is offline
post #10 of 39 (permalink) Old 09-29-2013, 08:19 PM Thread Starter
CometGSR's Avatar
Thanks!
I think I am going to try to get a set of Lincoln spares instead of going with a 15" rim. I would imagine the rims themselves would be cheaper and they wouldn't be used much. If you are spending $150+ each tire, you might as well not compromise.
-=James
CometGSR is offline
post #11 of 39 (permalink) Old 09-29-2013, 09:10 PM
1MTNCAT's Avatar
Thanks!
Just find a stock set of Lincoln Mark VIII aluminum factory rims in 16 Inch to use just for track purposes. They will work fine on any of the 16 inch drag radials you plan to use. That being said go with a 255-50-16 or a larger 275-60-16 if they are available. Check the specs on those as well. Remember, the stock tires are approximately 26.8 inches tall. The stock rims width will work with either of them for drag purposes.
You will be running a lower tire pressure but you only need to go as low as what it takes for the car to hook. Trial and error. The more pressure you can run with and still pull good consistant 60's with only slight wheel spin the better off you are. Less rolling resistance down track, more stable and better MPH out the top end.
Steve
1MTNCAT is offline
post #12 of 39 (permalink) Old 09-29-2013, 09:35 PM
Would 255-50-16's on sport rims treat me any better than 245-45-17's on my current rim? Because those are what I've been looking at. Along with some skinnys up front. What size fits the 16" aluminum SC spare rims?
post #13 of 39 (permalink) Old 09-29-2013, 10:09 PM
1MTNCAT's Avatar
Probably the 255-50-16s. I've used them NA and had success with them. More sidewall seems to work better with an IRS due to Flex at the sidewall. Just my experience with drag tires both NA or with a power adder over the years. Thats why I prefer to run 15" wheels. Lot more selection of tires between 26"-29" and more sidewall to absorb some of the IRS shock.
You need to find a set of 15" aluminum front spares and run a 27" tall front runner for the track. You can run the 16's on the rear for the track.
Steve
1MTNCAT is offline
post #14 of 39 (permalink) Old 09-30-2013, 10:37 AM
T6Rocket's Avatar
I would find a cheap 15x8 wheel, slap some M/T 255/60-15's and let 'er eat! Just run the stock 15x6's on the front, no need to spend money on front runners.
Al
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is offline
post #15 of 39 (permalink) Old 09-30-2013, 11:45 AM
keep in mind some tracks wont let you run spare tire rims on the track it depends on how picky tech is.
teal9550 is offline
post #16 of 39 (permalink) Old 09-30-2013, 01:46 PM
They can't stop you from using spare rims as long as they have DOT tires on them, I have had to get out and show them several times.
post #17 of 39 (permalink) Old 09-30-2013, 08:25 PM Thread Starter
CometGSR's Avatar
Another question.. Why do we need 4 drag radials when our cars are not AWD? It seems that a lot of people do that here.
-=James
CometGSR is offline
post #18 of 39 (permalink) Old 09-30-2013, 08:42 PM
1MTNCAT's Avatar
Now thats hillalrious ROFL!!!!
Steve
1MTNCAT is offline
post #19 of 39 (permalink) Old 09-30-2013, 08:51 PM Thread Starter
CometGSR's Avatar
I have seen it done here, many times. It was a serious question. LOL
-=James
CometGSR is offline
post #20 of 39 (permalink) Old 09-30-2013, 09:58 PM
Autocross.
post #21 of 39 (permalink) Old 10-03-2013, 11:45 AM Thread Starter
CometGSR's Avatar
After finding out that the LS rims would require SPACERS I decided to go back to 15". My current wheels are P215/60R16 but the BF Goodrich is a similar P235/60R15. I found a set of 15x6.5" rims for cheap on Craigslist, so I am going in that direction.
Other than the ugly rims, does anyone have further suggestions or think what I am doing is dumb? Sorry, I am a bit of a Newb at drag tires.
-=James
CometGSR is offline
post #22 of 39 (permalink) Old 10-03-2013, 12:44 PM
T6Rocket's Avatar
I would try to find a cheap 15x8 wheel, and slap some M/T 255/60-15's on there. A 6.5" wheel is too skinny IMO, destined for "also ran" status.
Al
Previous Fords:
T6Rocket is offline
post #23 of 39 (permalink) Old 10-03-2013, 12:59 PM
http://www.car-part.com/images/interchange/W3323.gif
I ran Ls rims in the rear of mine with ET streets no problem. Don't know about the front.
bulldog is offline
post #24 of 39 (permalink) Old 10-03-2013, 01:18 PM
rbohm's Avatar
you can use the rims you bought for drag radials while you learn. just get the largest tires that will fit the rim, and run a slightly lower pressure to get the maximum footprint.
my mind is aglow with whirling transient nodes of thought careening through s comic vapor of invention.
rbohm is offline
post #25 of 39 (permalink) Old 10-03-2013, 02:35 PM
r429460's Avatar
Do it right the first time.
Do not run a rim thats too narrow for the tire and use a lower air pressure.
That will give you a loose feeling at speed.
If you run a narrow rim, use a narrow slick, (DR).
You are better off with a slightly wider rim, and a slightly narrow tire.
This will keep the air pressure higher.
Hence, a more stable top end.
Quickest N/A Modular MN12.
01/31/18 PBIR
THE danner EATER
r429460 is offline
post #26 of 39 (permalink) Old 10-03-2013, 02:48 PM Thread Starter
CometGSR's Avatar
This is a 15x6.5" rim, which BFG says is the narrowest rim you can put on. I believe it is the same as the MN12 rims. If it was 6", I would agree with you.
If I could find a 15x7 or 8 rim in our bolt pattern, that would work better for sure.
-=James
CometGSR is offline
post #27 of 39 (permalink) Old 10-03-2013, 05:52 PM
rbohm's Avatar
i agree, thats why i said get the largest tire that fits the rim. remember tires are designed for a range of rim widths. for instance a tire that has a design rim width of 7", can fit a range of rims from 5.5-8.5 inches.
rbohm is offline
post #28 of 39 (permalink) Old 10-03-2013, 08:34 PM Thread Starter
CometGSR's Avatar
I wish they made more sizes. It seems that if you really want to set this up right you would need to go with non-factory wheel options. MT makes a bunch of sizes for the 7" wide rims, but that is hard to find in our bolt pattern without going aftermarket.
I see why people change out their bolt pattern, ours suck.
-=James
CometGSR is offline
post #29 of 39 (permalink) Old 10-03-2013, 08:55 PM
1MTNCAT's Avatar
The 235-60-15's will work fine for your application and wheel.
Steve
1MTNCAT is offline
post #30 of 39 (permalink) Old 10-07-2013, 11:48 AM
T6Rocket's Avatar
Pick M/T's over BFG's. On BFG's, the rubber shreds off in pieces with every burnout and they pick up every stone in the road. Fastest wearing DOT drag radial out there.
Al
Previous Fords:
T6Rocket is offline
