Niche Scope T10 - TCCoA Forums
post #1 of 6 (permalink) Old 10-11-2013, 02:46 PM Thread Starter
Awaiting E-Mail Confirmation
Niche Scope T10
I am looking to install these wheels on my 94 SC.
http://www.nicheroadwheels.com/scope-t10--w-3346.htm#
It is only available in 19 & 20 diameters with 8.5 and 9.5 inch widths respectively.
I was hoping to get some offset recommendations with out rolling the inner fender front or rear. Since they are custom I can play with thins a little.
Cheers
Swervin
Swervin is offline
post #2 of 6 (permalink) Old 10-11-2013, 03:35 PM
Swervin,
I do not think that the available bolt patterns will work for you !
Good Luck,
Sonny
Sonny Day Out is offline
post #3 of 6 (permalink) Old 10-11-2013, 03:48 PM Thread Starter
I think those bolt patterns are a max pattern. The spec sheet leaves a spot for custom bolt circles.
Swervin is offline
post #4 of 6 (permalink) Old 10-11-2013, 03:49 PM
5x120 or 5x130?!? Yeah that won't work.
post #5 of 6 (permalink) Old 10-11-2013, 04:04 PM Thread Starter
Here is the spec sheet
I have to decide to do the hub swap or not but I should be able to choose the bolt circle either way.
Swervin is offline
post #6 of 6 (permalink) Old 10-11-2013, 04:09 PM
If you say so. FWIW the only hubs you can swap to are the Mustang's 5x114mm
