20s - TCCoA Forums
post #1 of 7 (permalink) Old 11-14-2013, 07:44 PM Thread Starter
20s
Ok I'm planning of getting a 20"x8.5" wheel with a +42mm offset and a 245/35/20 tire size. Does anyone know how this will sit the car is stock height at the moment but do plan on dropping 1.5"-2" down the road
Public Disturbance is offline
post #2 of 7 (permalink) Old 11-14-2013, 08:58 PM
The tires are only .2 inches larger in diameter than a 225/60 16 which is a stock size, one of the many tire size calculators on the web would be a good place to start comparing.
Bangster is offline
post #3 of 7 (permalink) Old 11-14-2013, 11:40 PM Thread Starter
I know height wise I'm talking offset clearance
post #4 of 7 (permalink) Old 11-15-2013, 11:32 AM
All,
.09" Deeper width ! Try http://www.rimsntires.com/specs.jsp?...&text1=&text2=
Good Luck,
Sonny
Sonny Day Out is offline
post #5 of 7 (permalink) Old 11-16-2013, 08:46 AM Thread Starter
That link is freakin awesome thank you so much
post #6 of 7 (permalink) Old 11-16-2013, 11:30 AM
That is a cool site, here is that page with what I am running on my 97 Mark VIII (and ran on my 97 Cougar, 89 Cougar with the old spindles, and 89 Cougar with 93+ spindles). I have to run a 3~5mm spacer so they don't rub on the 93+ spindles.
As most of the aftermarket 9 inch wide 17 and 18 inch wheels for our cars are 36mm, 42mm with 8.5 inch wheel is the same backspacing, so be .5 inches more sunken in but with the same 6.4 inches of backspacing (I don't know what the offset for factory 15 or 16 inch wheels are, but measured backspacing is 5 inches, 5.5 inches to the lip).
Bangster is offline
post #7 of 7 (permalink) Old 11-19-2013, 02:44 PM
I've got a 20X9 with +36 up front. That 20X8.5 will have the same backspace as my rims, but sit 1/2 inch further inboard. This isn't a great pic of the front wheels, but you can see how they sit in relation to the body.
http://www.sccoa.com/forums/garage_a...tach_type=full
'89 T-Bird M5R2
433 RWHP/ 424 RW torque
2.0L AutoRotor Power
Micahdogg is offline
