rim size - TCCoA Forums
post #1 of 7 (permalink) Old 12-31-2014, 06:20 PM Thread Starter
rim size
I know my lx runs a 15 which are near bout impossible to find a used set today i searched i could of got 195 or 235. Didnt knoe if the 235's would of rubbed or not.
Im thinking about upgrading rims to a size thats more commonly found.
Dont the sc's run 14 inch rims while the lx is 15 and the sport birds (spiral swirl rim) run a 16?
94thunderbird46 is offline
post #2 of 7 (permalink) Old 12-31-2014, 08:02 PM
No MN12 ever used 14" wheels. SCs, 96/7 Sports, 89-92 XR7s and Mark VIIIs all used 16" wheels, the rest used 15s
235s fit fine, just make sure you select an aspect ratio close to the factory tire height
post #3 of 7 (permalink) Old 01-01-2015, 08:34 AM Thread Starter
My aspect ratio is 70. So a 75-80 should be ok right?
My local yard crushed a mint 35th anniversary cougar. They said no one was pulling from it itd been there to long, had to go so i grabbed the wheel hubcaps. Wish ida go the rims..
Does the mark8 rims fit our hubs?
post #4 of 7 (permalink) Old 01-01-2015, 10:27 AM
You can run Taurus/Windstar wheels.
steveg1988 is offline
post #5 of 7 (permalink) Old 01-01-2015, 10:54 AM
Yup!
post #6 of 7 (permalink) Old 01-01-2015, 12:06 PM
Depends on treadwidth. For a given rim size, as you increase treadwidth, aspect needs to go down to maintain diameter. Total tire height needs to be within a few percent of the original size to maintain speedo accuracy.
There are a handful of tire size calculators out there you can play with. Optimal diameter for the MN12 is about 26.5".
post #7 of 7 (permalink) Old 01-01-2015, 03:22 PM Thread Starter
Tarus sho's?
