Lighter weight wheels and wider rims? - TCCoA Forums
post #1 of 4 (permalink) Old 02-13-2015, 07:27 AM Thread Starter
CometGSR's Avatar
I have been playing with the idea of swapping out the Windstar wheels or using them for drag radials. They are 16x6.5" size and currently have P225/60R16 Michelin Pilots All Seasons.
If I wanted to get a wider rim, 7 or 7.5", what would be benefit for traction (which is always a problem for me). When you put a wider rim on a tire, does it expand the foot print by that much of a margin? If I bought a rim that was, say, 16-18LBS, would that help me any? I would imagine these mini-van rims might be a bit heavier. I would like to stay with 16" because the Michelins don't have very many miles on them but I bought them 3 years ago.
What do you think?
-=James
1995 Ford Thunderbird V8
SCT Tuned by Amercian Motorsport, Mustang PBR, FRPP 3.73 gears, Modified Trak-Lok, Steeda UDP, K&N Panel, 1990 SC Seats, 2.5" Single Exhaust/Magnaflow Hi-Flow Cats, Michelin Pilot Sport A/S +, Windstar wheels, RichardM Intake, Kenwood KDC-HD552U HD Radio, 2800 stall DirtyDog Marauder TC, J-MOD, 2002 Grand Marquis transmission, DynoTech Driveshaft, AeroForce Interceptor Scan Gauge, Griffin Super High Capacity Radiator, 180* Thermostat, Cobra steering wheel, 6000K HID, Clear Corners Getting a makeover Spring 2015
http://www.fordthunderbird.net - For Pics and more!
CometGSR is offline
post #2 of 4 (permalink) Old 02-13-2015, 08:53 AM
James,
Switching to a wider rim will not make the footprint any larger, but it will improve handling. Thunderbirds with the Sport option came with 7" wide wheels and your tire size.
MikeB
1997 Thunderbird Sport
5.0L-2V PI S/C
540 RWHP / 492 RWTQ
11.28 @ 123 MPH
MikeB is offline
post #3 of 4 (permalink) Old 02-13-2015, 08:55 AM
On a 225 tire, going from a 6.5" to a 7.5" rim isn't going to make much of a difference because the 225 is within the normal range for the 6.5" rim. If you were running 245s on a 6.5" rim, then stepping up to a wider wheel would make more of a difference. As for the weight, I don't know how much windstar wheels weigh compared to SC wheels or Taurus wheels or something like that, but the lighter the wheels, the easier it is to accelerate, brake, or turn them.
post #4 of 4 (permalink) Old 02-13-2015, 01:01 PM
r429460's Avatar
Don't cheap out wjth your rims.
The wider the better.
For any type of racing the higher you can run your air pressure
the better the contact patch of the tire.
An example, drag cars running in the 10.5" tire class, they are running 14" wide rims.
That's to place a flat even strip of rubber down on the ground with firm sidewalls
for better handling at high speeds.
Quickest N/A Modular MN12.
01/31/18 PBIR
THE danner EATER
r429460 is offline
