spare tire options - TCCoA Forums
post #1 of 17 (permalink) Old 09-26-2015, 11:33 AM Thread Starter
spare tire options
Does anybody use 2000-2007 taurus 16' steel wheels as a spare? my doughnut is flat, and i am debating going with the bigger brakes, so my factory salad spinners will be rendered unusable.
steveg1988 is offline
post #2 of 17 (permalink) Old 09-26-2015, 11:52 AM
Lincoln LS. Those are 17"
post #3 of 17 (permalink) Old 09-26-2015, 12:16 PM Thread Starter
I have the LX Sport wheels.
post #4 of 17 (permalink) Old 09-26-2015, 12:49 PM
Dusty's Avatar
Depends on how big of brakes. The 16 should fit PBR brakes. I have a 16" mark 8 spare - just because I got it for $10 and it fits PBRs fine. If you go to Cobra brakes then I can't say.
1995 PI Tbird
1998 TA Vert
2004 Buick Regal GS
2000 Honda ST1100
1990 Mazda RX-7 2+2
Dusty is offline
post #5 of 17 (permalink) Old 09-26-2015, 12:50 PM
PBR brakes fit under 15s. Cobra brakes need 17s.
post #6 of 17 (permalink) Old 09-26-2015, 03:28 PM Thread Starter
I plan to just get the LX sport brakes if i do.
post #7 of 17 (permalink) Old 09-27-2015, 06:56 AM
bowez's Avatar
If you leave the rears alone you have no problems, spares that don't match should always go on the rear anyway.
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
post #8 of 17 (permalink) Old 09-27-2015, 12:14 PM
Black_Cat's Avatar
Mustang hub swapped, you need a 17" spare from a ford five hundred 05-07
2011 BMW X5 35i Premium Package
2009 BMW 535i ///M Sport Package
Black_Cat is offline
post #9 of 17 (permalink) Old 10-04-2015, 12:03 PM
I was after a better spare, one so that I could run the Cobra brakes but not have to swap 2 wheels around with a flat.
I didn't want to spend 150 bucks for one on eBay, sight unseen, so I just signed up for notifications when the local you pull it place got in any LSes. Even at the conventional junk yards they wanted over 100 bucks for a temporary spare.
After 4 LSes came in with the 16 inch spare, and one without, finally got one in. Only 12 bucks.
But these are not donuts, not by a long shot.
I have also tried a Volvo XC90 SUV 17 inch spare, it has a very funny offset and won't clear Cobra brakes.
I guess I will need to do a hub swap, redrill, and get new wheels if I want Cobra brakes and no nonsense flat protection.
Bangster is offline
post #10 of 17 (permalink) Old 10-04-2015, 12:14 PM
Well so much for that. FWIW the 5 x 114 five hundred spare I'm using is bigger than the factory donut as well but it JUST allows the cover to fit seamlessly, but you need trial and error the arrangement of things to get it just right
post #11 of 17 (permalink) Old 10-04-2015, 03:15 PM
Matt, is the 500 spare steel or aluminium?
97CatMan is offline
post #12 of 17 (permalink) Old 10-04-2015, 03:21 PM
It's steel, an aluminum Cobra spare would be preferable but I refuse to pay more than $20 for a used(even if never "used") temp.
post #13 of 17 (permalink) Old 11-01-2015, 09:37 PM
Woodman's Avatar
So I just bought 18x9" wheels, and plan on doing the cobra brake swap this spring. I will have my 16" sport wheels leftover, and since I run 255/40/18's with my 3.73 gears and have a perfect speedometer reading, I want to keep a tire in the 26" to 26.1" range. So, on my 16" wheels, a 215/60/16 has the correct outside diameter, but will it fit in the spare tire well without sticking up?
They're the same width as the stock 15" tire, but nearly a full inch shorter in OD. Narrower than the stock 16" tire, and again shorter.
Woodman is offline
post #14 of 17 (permalink) Old 11-01-2015, 10:18 PM
Nothing but a small donut tire/wheel will fit in the spare tire well. Unless you plan on running the spare for more than a temporary means there's no reason to match heights for it, otherwise just do fix a flat and a pump(lots of OEMs essentially equip that standard now)
post #15 of 17 (permalink) Old 11-02-2015, 05:49 AM
I picked a MK VIII spare a while back. But Bangsters pics put in mind PlanC. Rather than fighting to find a donut that will fit under the flimsy hardboard trunk trunk panel the always bends and flexes under the slightest weight and allows small objects drop through the crack between the tail light panel and the spare tire well cover why not just use a taller spare along with the tire cover from a Crown Vic or something and use the space around the spare to collect the small stuff that always seems to sneak under the trunk panel? You lose the flat floor but gain some storage space that should keep the smaller stuff from rolling around the trunk and rattling. And with the spare tire cover it would still look finished.
Anyone know if the CV or Town Car Spare tire cover is a full cover? I've never seen one in the flesh. I'm guessing it's a 3/4 or 7/8 style cover that you can yank off to expose the tire hold down hardware in the Panthers. I do know if I could find a full size spare cover in the same material as the trunk carpet I'd probably go that route. The factory trunk panels just seem a bit flimsy. But the DD is also the family truckster around here. So I'm guilty of trunk abuse.
97CatMan is offline
post #16 of 17 (permalink) Old 11-02-2015, 02:41 PM
Woodman's Avatar
I had a 2002 Crown Vic, and the spare tire cover is a 3/4 cover. It's set up so that you see the cover as you're looking in the trunk, in the upper right corner of the bay. The back is open, so you can slide it on.
Woodman is offline
post #17 of 17 (permalink) Old 11-02-2015, 05:23 PM
That kinda what I figured. Drat! Ford used the gray rat rug in the trunks for a long time. There's probably something out there.
97CatMan is offline
