custom sable wheels? - TCCoA Forums
post #1 of 6 (permalink) Old 01-17-2016, 01:09 PM Thread Starter
69ford99's Avatar
I found some custom 18" wheels a guy had on his sable they're 7.5" wide and have an offset of 42. The tires are 215/45/18. Id like to go with something a little taller but not sure exact size. Are those wheels gonna fit or be a little too close to the spindle?
69ford99 is offline
post #2 of 6 (permalink) Old 01-17-2016, 01:18 PM
The latter. You want these for looks I presume? Because narrow high offset wheels make these cars look like they're standing on tippy toes
post #3 of 6 (permalink) Old 01-17-2016, 01:19 PM
Yes, those wheels should fit just fine. The tires will be a little short and narrow for an MN12 though. With a 7.5" wheel, I would go with a 225/50/18, which is just slightly taller than the stock size.
post #4 of 6 (permalink) Old 01-17-2016, 04:08 PM Thread Starter
69ford99's Avatar
I also found some 2014 focus wheels, but havent decided yet.
69ford99 is offline
post #5 of 6 (permalink) Old 01-17-2016, 07:20 PM
Woodman's Avatar
Focus wheels are even higher offset, 50 for the 17", 55 for the 18". That makes them sit deeper inside the wheelwells.
on 18" wheels, a 35-36 offset is very good.
Woodman is offline
post #6 of 6 (permalink) Old 01-17-2016, 10:59 PM Thread Starter
69ford99's Avatar
Well i dont really want to put skinny tires on it, but the wheels/tires were a good price so I figured id see if they would work. I like my fan blades but need a change and would like a little wider wheel. Im gonna go with the cougar 7 spoke wheels with some 235/60/16 tires. I want to paint them either black or charcoal grey, not sure which would look better with the pumice metallic paint. Is there a t-bird center cap that will fit those wheels?
69ford99 is offline
