New Shoes for the Project - TCCoA Forums
 1Likes
  • 1 Post By MaddMartigan
post #1 of 8 (permalink) Old 01-25-2016, 08:14 PM Thread Starter
MaddMartigan's Avatar
I ordered new shoes for the bird yesterday. Just figured I would share.
Edit; I thought about this more and realized I should disclose more of the plan. The wheels are 18x9 on 5x114.3 with a 30mm offset. I am planning to use P275/40-18's all the way around the car. I will obviously be doing a hub swap. I plan to road race the car and since I needed new wheels this is what I settled on using. These wheels are flow formed since I wasn't willing to pay for actual forged wheels. I realize that they may stick out a little but inside clearance was the bigger concern because of the tires. This isn't a daily driver so the usual concerns don't concern me.
OxmanWI likes this.
1992 Ford Thunderbird SC
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.27 gears
Custom aluminum driveshaft
M5R2
Burned Chip for SN95 T4M0 ECM
OMGHI2U
MaddMartigan is online now
post #2 of 8 (permalink) Old 01-25-2016, 08:37 PM
DisturbedBird's Avatar
I like those! Can't wait to see them on the car.
DisturbedBird is offline
post #3 of 8 (permalink) Old 01-26-2016, 08:38 AM
Woodman's Avatar
Very nice! Those will look good!
Woodman is offline
post #4 of 8 (permalink) Old 01-26-2016, 10:12 AM
CDsDontBurn's Avatar
Sick wheels man!
CDsDontBurn is offline
post #5 of 8 (permalink) Old 01-26-2016, 12:41 PM
Rayo's Avatar
18x9 with a +25mm offset?
1991 Ford Thunderbird Sport
Rayo is offline
post #6 of 8 (permalink) Old 01-26-2016, 12:56 PM Thread Starter
They are actually being customized to my needs. They will be 5x114.3 bolt pattern and 30mm offset. The chosen offset is both a limit to how much can be removed from these flow formed wheels and of the fact that I plan to run 275's all of the way around.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #7 of 8 (permalink) Old 01-26-2016, 01:13 PM
Rayo's Avatar
That's pretty cool..
Are they starting with a fresh wheel custom spec to your needs, or simply removing some meat from the back of the wheels?
Basically bringing them inboard for every mm of material they remove from the wheel..
Rayo is offline
post #8 of 8 (permalink) Old 01-26-2016, 01:38 PM Thread Starter
They are "blanks" in that they don't have a bolt pattern drilled but they will machine off the 5mm needed since they are already formed.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
