Can it be done? - TCCoA Forums
post #1 of 8 (permalink) Old 04-04-2016, 08:54 PM Thread Starter
Black_Cat's Avatar
Can it be done?
285/40/18 on an 18x9 with +26mm offset. Thinking about having my rear lips rolled.
2011 BMW X5 35i Premium Package
2009 BMW 535i ///M Sport Package
Black_Cat is offline
post #2 of 8 (permalink) Old 04-04-2016, 09:09 PM
Woodman's Avatar
I'm thinking probably. If it were me, I'd measure the dimensions between the rear tire and the suspension, the wheel well, and the inner fender as it sits now, plug that info into this calculator Rim & Tire Size Calculator. Custom Offsets - Wheel-Size.com and take a look.
The measurements in this link came off my front suspension. Rear tucks in just a little more I think, but I'd definitely want to roll my fender lips if it were mine.
Woodman is offline
post #3 of 8 (permalink) Old 04-04-2016, 09:21 PM
I have +26mm on my 17x9s and rarely rub with 255s, though they do occasionally. I think 285s with a taller tire would absolutely need it, the tire will stick out a bit no matter though.
post #4 of 8 (permalink) Old 04-04-2016, 09:26 PM
Send a message via AIM to Red97Tbird
I'm running 285 40 18 on a 18x10.5 wheel. Wheel has a crap load of off set. Not sure how much. That was with out the fenders rolled. Just rolled the fenders to make room for some 295 40 18 or a 305 40 18. There are some pictures on the forums, where I posted pictures of the room with tires.
Red97Tbird is offline
post #5 of 8 (permalink) Old 04-04-2016, 10:07 PM Thread Starter
Black_Cat's Avatar
I must find this.
post #6 of 8 (permalink) Old 04-05-2016, 07:00 AM
Here are some old pictures. Same wheels I have now but a 275/40/18 tire. Only time I had issues with the 285's is when I would hit a big dip in the highway. They would rub a little. Heavy Duty Roll Fender Reforming Extending Tool Wheel Arch Roller Flaring Former | eBay
Here is the link to the fender roller I just bought. It's only 52 bucks shipped from ebay. Worked great, just take your time with a heat gun and you won't have any issues doing it your self.
4.6 explorer motor,Water meth injection, V1 Vortech, 3.48 pully,BBK 78mm, Dirty Dog 9.5 converter 3500 stall, RobertP built trans, 8.8 rear with trac lock, 3.73 gears, BrainCoating manifolds, Dual 2.5" exhaust.
post #7 of 8 (permalink) Old 04-05-2016, 07:49 AM Thread Starter
Black_Cat's Avatar
Looks pretty good, I have a guy here locally who does fender rolling as a side job, and he does tons of cars. Will probably get him to do it, if yours clears that well with 18x10.5 and 285's, I should be well in the clear with a 9" sporting 285's.
post #8 of 8 (permalink) Old 04-27-2016, 08:32 AM
I'm running 285/35/19 on the rear with a +45MM offset. No Rubbing yet.
bulldog is offline
