18x8 40mm offset fitment question - TCCoA Forums
post #1 of 4 (permalink) Old 06-30-2016, 12:22 AM Thread Starter
281_TBird's Avatar
Guys, thinking of replacing my current 18x8.5 35mm offset wheels with 18x8 40mm offset wheels. ( I like the look of these new ones better than what I've got). Do you guys think they are going to look too sunken in to what I've got now? I hate the look when the wheels are tucked way in. Thinking of maybe running a spacer to make up the difference but I've never liked the idea of running a wheel spacer. Let me know what you guys think. Thanks.
1997 Ford Thunderbird, Built NA 2V/ T-45
1997 Ford Explorer AWD 5.0L
2003 Lincoln LS V8 Bolt Ons
2009 Yamaha VMax
2011 F-150 Lariat Limited 6.2L 4WD
2015 Ford Mustang GT Premium, Performance Pack, Recaros
281_TBird is offline
post #2 of 4 (permalink) Old 06-30-2016, 03:25 PM
Woodman's Avatar
This is a great website for tire calculations.
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
According to this, if you go with a 245/45/18 tire, which is the same outside diameter as a stock 225/60/16, your new setup will stick out .4" more than previous, and will also extend inward .4" (because the wheel is one inch wider than the outgoing wheel) The tire is also .7" wider, so you'll have about .35" more width on either side.
Woodman is offline
post #3 of 4 (permalink) Old 07-10-2016, 07:19 PM
fugby's Avatar
KMC Wheels KM775 Rockstar Car Matte Black Wheel (18x8"/5x108, 114.3mm, +42mm offset) These are my wheels. Mounted Nitto G2 255's. Had slight clearance problem with fronts, but 10 minutes with a dremel and medium stone solved it. No spacers required.
fugby is offline
post #4 of 4 (permalink) Old 07-10-2016, 08:06 PM
Woodman's Avatar
If you can get a 35 or 36mm offset, the wheel will move away from the middle of the car, but not too far to rub on anything. The larger the number, the closer to the suspension it gets.
Woodman is offline
