American Racing Wheels - TCCoA Forums
 7Likes
  • 1 Post By miller1995
  • 1 Post By Matt_aka_Dale
  • 1 Post By XR7-4.6
  • 1 Post By Grog6
  • 1 Post By Bangster
  • 1 Post By ogbird95
Old 07-08-2016, 04:13 PM Thread Starter
Matt_aka_Dale's Avatar
It looks like the certain style of wheels I would like are only available in 17". I would rather have 18", but if Vogtland 1" drop springs make it too close, then I guess that's fine. I just don't want too much of a gap between the top of the tire and the fender. What would be some recommendations?
Matt_aka_Dale is offline
Old 07-08-2016, 05:15 PM
miller1995's Avatar
The wheel size has no bearing on the tire height.
Woodman likes this.
SOLDWhite '03 Crown Vic P71
SOLD2006 Mazdaspeed6
SOLD1998 Escort ZX2
RIP My Black 95 LX 4.6
miller1995 is offline
Old 07-08-2016, 11:04 PM
Woodman's Avatar
This.
The equivalent tire size to 225/60/16 is a 245/45/18, same outside diameter as the 225/60/16, less sidewall, fills up the wheel wells the same. Offset is more important, as you need in an 18x9 around 35 or 36mm offset for good overall clearance.
Woodman is offline
Old 07-08-2016, 11:54 PM Thread Starter
I understand that, however, the AR wheels are only in 17". It confuses me
Old 07-09-2016, 10:05 AM
Woodman's Avatar
We're confused by your earlier statement about worrying about the tire to fender gap. That has absolutely no bearing on wheel size, as you would just fit a tire with the correct outside diameter.
Sadly, the 245/50/17 (correct outside diameter) isn't a hugely popular size, so there aren't a ton of tires, but there are some good ones available.
If you get your 17" wheels, and 245/50/17 tires, the tire to fender gap will be identical as your 225/60/16 tires or your 215/70/15 tires.
Woodman is offline
Old 07-09-2016, 11:12 AM Thread Starter
I apologize if this is even confusing to you guys. I just don't get fact that the site lists the wheels in multiple sizes, but only picks 17" for the vehicle. Am I missing something?
And I tried The Custom Wheel Shop for some wheels but, I can't 'check out' and see what shipping would be because the site errors.
I think I'm just not allowed to get wheels
Woodman likes this.
Old 07-09-2016, 11:30 AM
They may only make them in a certain bolt pattern and offset, even if there are other versions of the same style wheel in different diameters
Woodman likes this.
Old 07-09-2016, 02:21 PM
There are few wheels made for our cars, which is why the Mustang Hub Swap is so popular.
Woodman likes this.
Old 07-09-2016, 05:27 PM
Depends on the width of the wheel, but for my 9 inch wide wheels I run 255/45/17 (which are .5 inches shorter). When I had 7.5 inch wide wheels I ran 235/50/17 (which are .2 inches shorter).
I wish I had gotten the 18 inch wheels. Back in 2004 when I got them the 18s were 500 dollars more than 17s, and the tires were generally double. A little short sighted, at least I don't run the 245/45/17 any longer, they are an inch shorter and right at the edge of being wide enough for a 9 inch wheel. They were cheap because it was a popular size for Mustangs.
Woodman likes this.
Bangster is offline
Old 07-09-2016, 05:31 PM
Woodman's Avatar
I run 255/40/18 on a 18x9 myself. For whatever reason, with my 3.73 gears and whatever speedo gear I have it makes my speedometer read perfectly. They are approximately .6" shorter that stock.
Woodman is offline
Old 07-09-2016, 09:59 PM Thread Starter
Any thoughts on why the Custom Wheel Shop's website crashes? Or does everyone just call the place?
Old 07-09-2016, 10:42 PM
Woodman's Avatar
Calling is the best way. Apparently the website design from 1999 is good enough for his purposes.
Don't neglect ebay. I got my wheels there, and love them. 5x108, 18x9 with 35mm offset. I run 255/40/18 with no rubbing issues.
Woodman is offline
Old 07-10-2016, 12:08 PM Thread Starter
It's the same bolt pattern as my 2003 Taurus. Because I'm currently using those Taurus wheels.
Old 07-10-2016, 10:45 PM
ogbird95's Avatar
Remember its not about the diameter of the wheel, but rather the width of the tire.
Woodman likes this.
ogbird95 is offline
Old 07-11-2016, 08:13 PM Thread Starter
I can find wheels on eBay just fine. However the wheels I can't find are the Cobra style 5 spoke. Now those are on the CWS...I just need to remember to call
Woodman likes this.
