You guys like these? - TCCoA Forums
 1Likes
  • 1 Post By XR7-4.6
post #1 of 9 (permalink) Old 01-16-2017, 08:24 AM Thread Starter
Bird-Aholic
Natesriv's Avatar
Natesriv is offline
post #2 of 9 (permalink) Old 01-16-2017, 10:07 AM
Kenz's Avatar
They appear directional, so they would be pointed differently on each side of the car. Some of the stock Tbird wheels are like that, and IMO looks goofy.
I noticed tirerack has quite a few new wheels in stock recently that fit our cars. Check them out too. They also roadforce balance all their tires/wheel packages too which is a big plus. I am hesitant to buy wheels or tires on ebay; an out of round or poorly weighed wheel and tire can be a big pain in the ass to deal with.
96 Cougar Sport - T45 Swapped
Kenz is offline
post #3 of 9 (permalink) Old 01-16-2017, 10:12 AM Thread Starter
Bird-Aholic
Natesriv's Avatar
damn, you're right!
Sent sell a question on if they make a left & right...
That is odd... I'd be bugged by that to no end!
Natesriv is offline
post #4 of 9 (permalink) Old 01-16-2017, 01:12 PM Thread Starter
Bird-Aholic
Natesriv's Avatar
Confirmed with seller...directional.
So tire rotations would be awkward!
Natesriv is offline
post #5 of 9 (permalink) Old 01-16-2017, 02:39 PM
Tire rotations would just be front to back, which is what they should be anyway, since reversing the rotation of radial tires can cause the belts to separate.
As for the wheels, my complaint about them is the same one I have with almost all aftermarket wheels, which is that they look like aftermarket wheels!
post #6 of 9 (permalink) Old 01-16-2017, 02:41 PM
Woodman's Avatar
I like them, if I were in the market for a 17" wheel, I'd consider them.
Woodman is offline
post #7 of 9 (permalink) Old 01-16-2017, 03:27 PM
I like them too, basically a bigger SC wheel design wise, and the stock fanblades are directional too, so who cares? Just rotate front to back only like you would if you kept them.
Woodman likes this.
post #8 of 9 (permalink) Old 01-16-2017, 06:45 PM Thread Starter
Bird-Aholic
Natesriv's Avatar
Too late, it's in my head now, I can't unsee it!
Natesriv is offline
post #9 of 9 (permalink) Old 01-16-2017, 06:50 PM
Kenz's Avatar
If they are side specific left and right wheels that's cool. I meant I don't like them if they were not... when they look like they are going different ways on passenger and driver side it looks strange. I have seen a few cars like that. I think some of the early 90s Cougar OEM wheels are like that.
My 96 Tbird had the directional double spoke wheels. It's not an issue rotating them, you just go front to back. I always thought that you shouldn't switch sides anyway when you rotate.
Kenz is offline
