Typical will this wheel fit question - TCCoA Forums
 2Likes
  • 1 Post By Thundernerd
  • 1 Post By Trunk Monkey
post #1 of 4 (permalink) Old 03-12-2019, 06:55 PM Thread Starter
Wondering if I've done my math correctly.
Bird is Eibach lowered 1.5 inch.
The wheel is an Advanti Racing Cammino 18x8/5x108 --- with 45mm of offset!!
The tire will be a 245-45-18.
I'm figuring that the backspace on that wheel is about 6.27 inches.
If I used a 3mm wheel spacer to bring the offset to 42mm and backspace to 6.17 inches,
do you think that would be enough?
I'm kina stuck on this wheel since it's the closest, IMO, to my soon to be retired set of Borbet FS - which
is no longer being made.
I need to upgrade because the new motor with four cams (NMW4Cs) started up for the
first time last week! (Thank you TCCoA for all the help)
Exhaust sys. goes in next week and my first ticket and summons will be shortly there after.
Thanks for any help
P.S.
I see that my "what I got list" is a little out of date
'95 LX 4.6L/ '99 mustang front calipers/ '96 t-bird rear calipers/Baumann transmission/BOC chip by Lonnie/ 225.55.16 Yokohama's on Borbet 5 spoke/poly IRS/ Eibach 1.5" drop/ Lincoln pumpkin with 3.55 trac-loc/ Lincoln rear upper and lower control arms/ rebuilding '94 Mark Vlll eng. for swap/ -Edit- Engine rebuild now finished by Panhandle Performance (2-16-07)/ swap on soon - but needing to get P.I. torque converter- MSD window switch for '98 IMRC'S- rebuild current Baumann Trans--etc.
Thundernerd is offline
post #2 of 4 (permalink) Old 03-14-2019, 10:46 AM
Woodman's Avatar
Thanks for any help
P.S.
It'll be tight, but probably fit. Ideal is 35 or 36 for an 18x8 or 18x9. I run 35, and I have about 1/2" clearance to the spindle.
They will tuck in significantly.
Here's a good calculation site.
https://www.wheel-size.com/calc/?whe...cl=64mm&sr=0mm
Woodman is offline
post #3 of 4 (permalink) Old 03-14-2019, 02:59 PM Thread Starter
Thank you very much Woodman, you saved me from a expensive error.
I have a calculation site but not near as good or as clearly illustrated as the one you posted.
I am using it!
Great job and thanks for taking the time to steer me in the right direction.
I'm gonna need a bigger spacer.
Woodman likes this.
post #4 of 4 (permalink) Old 03-14-2019, 03:10 PM
Great calculator. Thanks for sharing, I haven't seen that one before.
Woodman likes this.
Similar Threads
NOT your typical Cobra rims and brakes question lou General Tech 27 05-09-2012 07:37 PM
Not your typical intake manifold swap. 337 Engine - 4.6L & 5.4L 2 03-16-2005 06:54 AM
Typical Rice-Boy... Palmguy Racing 85 11-09-2003 03:44 PM
Typical 96?? JJanney Videos/Images 11 04-22-2003 05:29 PM
typical moron small car owner Earl Miscellaneous 1 10-16-2002 02:37 AM
