Bbs Sr wheels - TCCoA Forums
 4Likes
  • 1 Post By Fordmuscle53
  • 3 Post By Fordmuscle53
post #1 of 5 (permalink) Old 04-03-2019, 09:11 AM Thread Starter
Bbs Sr wheels
I'm looking for a set of wheels and tires for my 91 thunderbird, tire rack has the bbs SRs in a 18x8 with 42et on 245/45/18 tires or a 16x7 with 45et on 225/60/16 tires. I really like the idea of the 18s but unsure if they will fit right, the car is factory height now, but I have plans to lower 1.5 in. Any help would be greatly appreciated!
Fordmuscle53 is offline
post #2 of 5 (permalink) Old 04-03-2019, 04:44 PM
Woodman's Avatar
The BBS 18x8 with 245/45/18 should fit fine. They'll be 3/10" closer to the wheel wells, but our stock wheels sit inboard somewhat, so there should be clearance.
I would not personally go with a 16" wheel these days. Performance oriented tires are few and far between, when you can get tons of good, cost effective street performance tires with great treadwear and grip.
Woodman is offline
post #3 of 5 (permalink) Old 04-04-2019, 09:32 AM
I would also go with the 18s. They will fit good.
Here is my car with 20x9 +35et and then a comparison of my wheels to the 18" bbs.
Sent from my SM-G892A using Tapatalk
1995 SC------------------1994 SC----------------1993 LX
Black----------------------Red----------------------Grey
3.8-------------------------3.8w/bent rod---------5.0
4R70W--------------------M5R2--------------------AOD
2.4 AR in works---------2.0 Auto Rotor---------N/A
24psi----------------------15+----------------------none yet
450RWHP----------------322RWHP -------------who knows/who cares
[email protected]@[email protected]
BLOWN38 is offline
post #4 of 5 (permalink) Old 04-05-2019, 01:43 PM Thread Starter
Thanks guys! I will go with the 18s! I'll post a pic with them on!
Woodman likes this.
post #5 of 5 (permalink) Old 04-05-2019, 07:08 PM Thread Starter
Now it needs a drop!
BLOWN38, quickford and Woodman like this.
Similar Threads
BBS Wheels (Tire fit) Sideoiler Tires/Wheels 2 12-03-2007 07:58 PM
Cougar bbs wheels mn12xr7 Tires/Wheels 11 03-02-2004 10:08 AM
