Stock Wheel Pics Please! - TCCoA Forums
post #1 of 14 (permalink) Old 12-17-2003, 09:27 PM Thread Starter
Send a message via AIM to Hill1513
Hey guys. I'm getting some tires for X Mas and would like to see how 235/60/15s AND BIGGER look on the stock fan wheels. Submit those pics!
Thanks.
1969 Firebird Convertible TA clone - 455, 800 Edelbrock Thunder Series, Edelbrock Performer RPM, #15 heads - 2.11/1.77 valves Ported and Polished, 1.65 roller rockers, Solid Lunati - 243/251 duration @ .050 .518/.530 lift, 11:1 TRW pistons, Hedman headers, MSD Ignition, electric fan, true 2.5" dual exhaust, rebuilt 200-4R, 12-bolt w/ 4.10s, etc...
Hill1513 is offline
post #2 of 14 (permalink) Old 12-17-2003, 10:39 PM
Evil Poster
Pooperscooper's Avatar
Send a message via AIM to Pooperscooper
This is the only pic I got. I'll take some better one tomorrow.
245/60-15
Pooperscooper is offline
post #3 of 14 (permalink) Old 12-18-2003, 02:46 AM
Cougar Pilot
BlackCat94's Avatar
Thumbs up
245/60/15
BlackCat94 is offline
post #4 of 14 (permalink) Old 12-18-2003, 08:13 AM
JoeyICU's Avatar
buy 245/60 15s there sweet make the car feel so much beefyer and the wood factor....off the charts...tell all your friends you cant catch traction with them to
JoeyICU is offline
post #5 of 14 (permalink) Old 12-18-2003, 10:44 AM
I have a question. Doesn't putting a bigger tire on a stock rim throw of the cars calibrations (Speedometer, odometer, etc.)
tino is offline
post #6 of 14 (permalink) Old 12-18-2003, 10:47 AM
mamberg's Avatar
245/60-15's are VERY close to the size of the stock 70 series tires. You won't even notice the difference in the speedo.
mamberg is offline
post #7 of 14 (permalink) Old 12-18-2003, 12:30 PM
Maybe i'm missing something here. I heard that when you change the tire size you usually have to go to a bigger rim. Example my t-bird's stock tires are 215-70-15's. If i wanted to go to a higher number it would read this way 225-60-16 or 235-50 -17's. This is what a lot of people in the auto industry say. Is this wrong or did i do the math wrong.
tino is offline
post #8 of 14 (permalink) Old 12-18-2003, 01:41 PM
Draggin the Subframe
with Jesus now
RIP Buddy!
JoelBender's Avatar
the first number is the width of the tire. so 225 235 245 255 265 etc...
the second number is the sidewall height, 30 40 50 60 70 etc.
the last number is the wheel diameter, 15 = 15" wheel, 16 = 16" wheel 17 = 17" wheel etc.
The one, the only.........Bagged!.....Bottle Fed!......Thunderchicken!!
13.605 @ 99.46 & 13.608 @ 99.78 & 13.610 @ 101.72 on the bottle.
14.782 @ 94.46 at Cecil
14.792 @ 93.38 at Rockingham with new torque converter (2800 stall) 95% humidity, 82 degrees....
284.3 hp @ 4100 rpm, 370.4 ftlb @ 3600 rpm
Your friendly, run of the mill, Psychopathic moderator
NC Chapter Forum Carolina Thunder
TCCoA A-hole crew 2005 "DIASS"
JoelBender is offline
post #9 of 14 (permalink) Old 12-18-2003, 02:06 PM
rustyul's Avatar
according to this tire size calculator your speedometer with 24560R15 tires as opposed to the 21570R15 tires will be exactly 1% too fast. Certainly nothing to be concerned about....
Glen "RustyUL" Weldon
95 Thunderbird LX - 4.6
rustyul is offline
post #10 of 14 (permalink) Old 12-18-2003, 02:13 PM Thread Starter
Keep 'em coming guys!
I'm actually only worried about whether this size tire fits inside the wheelwells (both front and back) don't really want any tread to stick out.
If anyone has pics of their car directly from the front or back, that'd be great.
Thanks again.
Hill1513 is offline
post #11 of 14 (permalink) Old 12-18-2003, 03:34 PM
Evil Poster
post #12 of 14 (permalink) Old 12-18-2003, 05:11 PM Thread Starter
Thanks a lot Pooper...anyone else?
Hill1513 is offline
post #13 of 14 (permalink) Old 12-21-2003, 09:38 PM
DRROVER's Avatar
Here's 235/60 15s on stock rims w/Eibach springs...no clearance problems but the stock rims don't really provide adequate sidewall support for "spirited" cornering or quick lane changes. Should have at least another inch of rim width for 15" tyres!
Cheers,
DR
"If you can read this, thank a teacher....and since it's in English, thank a soldier."
I am a nobody, and nobody is perfect; therefore, I am perfect.
Eibachs, some of the mn12perf bushings,GT MAF sensor, K&N filter, RM Tube, Steeda UDs, Jmod w/deepsump, trans cooler, TRUBENDZ freeflowcats & X-pipe, and cat-back duals w/Flo 40s (done locally). 3.73 FRPP DIFF, ...SCT and ADDCO "BIG BARS"
DRROVER is offline
post #14 of 14 (permalink) Old 12-21-2003, 10:19 PM
I know they're not the stock fan wheels, but how about some 255/60-15's.
Nah, they're not wide enough.
-Rod
