Weight of Stock Wheels - TCCoA Forums
post #1 of 13 (permalink) Old 12-30-2003, 12:49 PM Thread Starter
Sweet T
SanDiegoLXBird's Avatar
I've got the stock 15" alloy wheels on my car and I was wondering if anybody had an idea of how much these things weight? I've never handled the rim without the tire on it, but these badboys feel pretty heavy with the tires on..
1994 SC 5-Speed
SanDiegoLXBird is offline
post #2 of 13 (permalink) Old 12-30-2003, 03:26 PM
Send a message via AIM to chrisnack
Yeah, they aren't all that light. But they are also a pretty big rim for a 15 (width is big).
I want to say 26lbs with the tire.. but i'm not sure on that.. that could be something else.. but I do have a 26 in my head for weight on smoeones rims with tires...
NSN Motorsports
http://www.nsnmotorsports.com
"Fordless" - But I do have alot of Mercon V laying around...
'96 Eagle Talon ESI
Parts ---> Dan Newman - Town & Country Ford - 800-847-2047
chrisnack is offline
post #3 of 13 (permalink) Old 12-30-2003, 09:29 PM
On Probation
blown96bird's Avatar
I weighed a stock wheel and it weighed 45 pounds. The stock steel mini spare weighs 26 pounds.
blown96bird is offline
post #4 of 13 (permalink) Old 12-30-2003, 10:35 PM Thread Starter
Sweet T
So 15lb wheel would be one hell of a weight savings...? And -120lbs of unsprung weight = -1.2seconds off of your 1/4? Yeesus.
1994 SC 5-Speed
post #5 of 13 (permalink) Old 12-30-2003, 11:13 PM
Wow.. i was off a bit
NSN Motorsports
'96 Eagle Talon ESI
post #6 of 13 (permalink) Old 12-30-2003, 11:32 PM
Refrigerator Raider Hater
GreenBird's Avatar
No. that rule of thumb isn't much of a rule, and the rule is one TENTH per 100lbs, so it would be .12 seconds.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #7 of 13 (permalink) Old 12-31-2003, 03:10 AM Thread Starter
Sweet T
Right 100lbs = .10 but I've also seen that 10 pounds of unsprung weight will yeild a tenth also.
1994 SC 5-Speed
post #8 of 13 (permalink) Old 12-31-2003, 09:18 AM
GreenBird's Avatar
unsprung weight is better to get rid of, but it's not 10 times, more like 2 or 3 for drag racing.
96 Alpine Green V8
post #9 of 13 (permalink) Old 12-31-2003, 11:26 AM
johnaec's Avatar
That's not right! (Unless you're including the tire.) I recently shipped out a set of stock 96 LX rims, and including approx 10 lbs for boxes and wrapping, each set of two came out to 54lbs. That's for two wheels and two boxes each, (I taped two boxes together with 1 wheel in each, for 54lbs), so each wheel is absolutely under 25lbs!
John
'96 T-Bird 4.6 LX, SVT Cobra Rs, 245/50R17 BFG Comp T/A, D-chip
johnaec is offline
post #10 of 13 (permalink) Old 01-16-2004, 11:33 PM
I just weighed a few of the 15x6.5" stock fan style wheels, they all weighed in just under 19lbs.
-Rod
post #11 of 13 (permalink) Old 01-17-2004, 12:47 AM
I would like to know some lighter wheels. Preferably 16 X 7 or 16 X 8 ? Even 17 X 8?
links anyone? All I find are _ X 7 or _ X 9's
1994 cougar sc springs 4 inch drop blistiens ford chip 180 t stat ffrp wires magnaflow muffs silencer removed, pair of 15's and about 8 grand of other misc stereo gear
aduty is offline
post #12 of 13 (permalink) Old 01-17-2004, 01:23 AM
XR7kid's Avatar
1 pound of unsprung weight is like 3 ( or 6 ) pounds of sprung weight
XR7kid is offline
post #13 of 13 (permalink) Old 01-17-2004, 01:12 PM
mercutio's Avatar
Unsprung weight is only part of the issue. Your lower a-arms are unsprung weight, but your wheels and tires are rotating mass, and rotating mass is THE most important weight to remove from your car. It's much better to remove 10 pounds per wheel than ten pounds per A-arm, spring, or whatever. That's why people use ultralight rotating assemblies in race engines.
mercutio is offline
