RIM OFFSET 5x108 offset is +25/40mm - TCCoA Forums
post #1 of 5 (permalink) Old 02-20-2004, 12:32 AM Thread Starter
Send a message via AIM to Jstaib Send a message via Yahoo to Jstaib
will these fit on my tbird
i found rims with these specs
i no they will fit
but will they fit right w.o sticking out or what ever
if not lmk plz
Jstaib is offline
post #2 of 5 (permalink) Old 02-20-2004, 01:47 AM Thread Starter
o yeah and 73.85 mm bore i belive
plz lmk ;0
Jstaib is offline
post #3 of 5 (permalink) Old 02-20-2004, 09:36 AM
johnaec's Avatar
I'm not sure about the bore - you may need to get a set of hub-centric rings. But 25/40 mm offset?? Does that mean you can order them either size? The T-Bird is 39mm, so you'd want the 40mm. 25mm would put the center of the wheel over .6" outside the centerline of the bearings...it would work, but wouldn't be ideal...
John
'96 T-Bird 4.6 LX, SVT Cobra Rs, 245/50R17 BFG Comp T/A, D-chip
johnaec is offline
post #4 of 5 (permalink) Old 02-20-2004, 01:31 PM Thread Starter
well the thing is
their from a pvt seller and im getting a deal
so u think they will look good or fit well or not worth the risk?
Jstaib is offline
post #5 of 5 (permalink) Old 02-20-2004, 03:40 PM
johnaec's Avatar
You need to find out if they're either 25mm or 40mm offset - they can't be both. Personally, I wouldn't get them if they're 25mm. If they're 40mm and you like their looks, you're probably OK...
John
johnaec is offline
