Sychronizing Speedo w/ bigger wheels/tires - TCCoA Forums
post #1 of 5 (permalink) Old 02-22-2004, 12:19 AM Thread Starter
Bradley Blaze's Avatar
Send a message via AIM to Bradley Blaze
I am about to put my 255/50/17's on my car. How bad, if any will it throw off the speedo, and how do I correct it? Also I am gonna put my 15's back on next fall to drive thru the winter. How can I find a 15" tire combination that will be the same overall diameter of the 255/50/17's? Thanks, BZ
Bradley Blaze
I'd Love to Live Life in the Fast Lane, but I'm Married to a Speed Bump
Bradley Blaze is offline
post #2 of 5 (permalink) Old 02-22-2004, 12:44 AM
Send a message via AIM to chrisnack
That is 4% over. so if you are going 60mph on the speedo, you are actually doing 62.4
http://www.miata.net/garage/tirecalc.html
NSN Motorsports
http://www.nsnmotorsports.com
"Fordless" - But I do have alot of Mercon V laying around...
'96 Eagle Talon ESI
Parts ---> Dan Newman - Town & Country Ford - 800-847-2047
chrisnack is offline
post #3 of 5 (permalink) Old 02-22-2004, 09:23 AM
fast Ed's Avatar
The speedometer calibration is done by changing the number of teeth on the driven gear that the speed sensor reads from. Since you're making a fairly small change in diameter, the next step fron what you have for a gear now would be too much of a jump.
The SCCoA site has a speedo gear calculator that's a bit easier to use for an MN-12 car, because it has a few of the variables listed for you already.
http://www.sccoa.com/faq/speedgr.html
As for 15" tires that will match the diameter of the 17" tires, 215-70-15 would be the closest, within 1/4".
cheers,
Ed Nicholson
SCCoO
88 T-Bird Turbo Coupe 5-speed
fast Ed is offline
post #4 of 5 (permalink) Old 02-23-2004, 12:48 PM Thread Starter
ok, how do I find out my rear end ratio, somrhting in the door jamb sticker right?
Bradley Blaze
post #5 of 5 (permalink) Old 02-23-2004, 01:19 PM
The Great Obucina's Avatar
yeah, it will be a single digit number under the AX key on the door jamb decal. The reference table is in the tech articles.
joseph
"Booyah". Stu Scott.
The Great Obucina is offline
