15x7.5 question - TCCoA Forums
post #1 of 9 (permalink) Old 03-05-2004, 08:17 AM Thread Starter
ZackG's Avatar
15x7.5 question
Ok, just a small beat the horse to death tire question. If the widest, best mate to road surface on a stock 6.5" rim is a 245, why cant i put a 49mm wider tire on my 7.5? Most of the tires I see that are around a 275 say the recommended rim width is 7.5"-9". Thanks
97 Tbird 4.6
Vortech at XY psi
4.10's, KB boost a spark.
Yummy.
ZackG is offline
post #2 of 9 (permalink) Old 03-05-2004, 12:42 PM
Refrigerator Raider Hater
GreenBird's Avatar
most tire companies recomend not going above 235/60 on a 6.5" wide wheel.
If you decrease the ratio from 60 to 55, the width has to be closer, so you have less range you can use.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #3 of 9 (permalink) Old 03-05-2004, 08:13 PM Thread Starter
ZackG's Avatar
i have a 7.5" wheel.
97 Tbird 4.6
Vortech at XY psi
Yummy.
ZackG is offline
post #4 of 9 (permalink) Old 03-05-2004, 11:45 PM
I don't know much about cars, but if the recommended width is 7.5" to 9" that means it will fit a 7.5" rim.
What is 49mm? Do they make tires with odd sizes like that? I've only seen 205,215,225,etc.
I'm confused.
Eric46v8 is offline
post #5 of 9 (permalink) Old 03-05-2004, 11:49 PM
GreenBird's Avatar
I know, but you said people were putting a 245 on a 6.5" wheel, which is not recommended, but people do so anyway. 245 is definately not the best, just the widest in 60 series.
So most companies say you can mount a 275 on a 7.5" wide wheel. Whats the problem? You can go beyond the recomended on a stock rim but not an aftermarket?
btw, what size wheel do you have? 17"?
96 Alpine Green V8
post #6 of 9 (permalink) Old 03-06-2004, 04:19 AM Thread Starter
ZackG's Avatar
15's
Eric46v8: i say 49mm since 1" = 49mm
97 Tbird 4.6
Vortech at XY psi
Yummy.
ZackG is offline
post #7 of 9 (permalink) Old 03-06-2004, 04:47 PM
Send a message via AIM to chrisnack
I would always look up the specs on the tire you are looking and go from there.
On a 16x7 rim a 225/60/16 is a very good fit.
I would never put bigger than a 235 on a 7" rim. But that is just me.
As far as I'm concerned a good 225 tire is going to grip better than a "ok" 245 tire.
I can spin the **** out of my winter tires all the way to 50mph, but my summer tires I can barely spin. And they are both a 215 width.
I'm getting 16" sport rims in a few weeks and Im going to put a 225/60/16 on them. Firestone Firehawk SZ50 EPs.
NSN Motorsports
http://www.nsnmotorsports.com
"Fordless" - But I do have alot of Mercon V laying around...
'96 Eagle Talon ESI
Parts ---> Dan Newman - Town & Country Ford - 800-847-2047
chrisnack is offline
post #8 of 9 (permalink) Old 03-06-2004, 11:36 PM
GreenBird's Avatar
1" = 2.54cm = 25.4mm
I would go with a 245/60-15. sure it's the same width but you don't want to go wider than 245 upfront anyway, and 245s on a 7.5 wheel will handle better than 245s on a 6.5 wheel.
96 Alpine Green V8
post #9 of 9 (permalink) Old 03-07-2004, 04:27 AM Thread Starter
ZackG's Avatar
alright, thanks for all of your help
97 Tbird 4.6
Vortech at XY psi
Yummy.
ZackG is offline
