30x10.5 DR - TCCoA Forums
post #1 of 9 (permalink) Old 03-08-2004, 08:18 AM Thread Starter
JoeyICU's Avatar
30x10.5 DR
whats the slimest wheel you can run with these...someone told me fan wheels but i kno thats insane and dangerous
JoeyICU is offline
post #2 of 9 (permalink) Old 03-08-2004, 04:16 PM
Bean Flicker
BlackTbird96's Avatar
Send a message via AIM to BlackTbird96
a 30" tire is a little tall for your car. Why so big?
BlackTbird96 is offline
post #3 of 9 (permalink) Old 03-08-2004, 04:41 PM
dode's Avatar
Good luck getting a 30" tire to fit in the wheel well unless you run a very wide rim.
John
1997 Mercury Cougar XR7
1992 Thunderbird GT 5.0L
dode is offline
post #4 of 9 (permalink) Old 03-08-2004, 06:39 PM Thread Starter
JoeyICU's Avatar
not mine....but yeah....so basiclaly shoot for like a 12" wide rim.....id figure around there
JoeyICU is offline
post #5 of 9 (permalink) Old 03-10-2004, 03:57 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
12" rims will not fit in the rear. 10.5 is the biggest I've seen fit and they stuck out an inch from the fender.
-Thomas
Thomas is offline
post #6 of 9 (permalink) Old 03-10-2004, 05:44 PM
4 Cam Bird's Avatar
Why would you mount a 10.5 inch tire on a 12 inch rim?
If you got the 30" tall tire to fit on your car, you are going to want like 4.30's in the back to offset the gear ratio change and get to a gear that would be desireable with a tire of a regular height.
2011 CTS-V Wagon
4 Cam Bird is offline
post #7 of 9 (permalink) Old 03-10-2004, 06:03 PM Thread Starter
JoeyICU's Avatar
4.10s are already there....its not my tire choice..but i was just curious...i would have shot for 26x10 DRs....but thats me
JoeyICU is offline
post #8 of 9 (permalink) Old 03-11-2004, 03:41 PM
4 Cam Bird's Avatar
I just went straight for slicks, but got a 26 x 8. 10 inch wide is too much for the stock wheel and they actually recommended a 5.5" wheel for the 8 " slicks.
2011 CTS-V Wagon
post #9 of 9 (permalink) Old 03-11-2004, 07:03 PM Thread Starter
JoeyICU's Avatar
thats a good size then...for when i get slicks...i thought they were to big also...i know they wont fit under a bird....do they have a 26x9 slck....like..the best size for that would be 6.5 witch is the fan wheel....and there not to heavy for a wheel at all
JoeyICU is offline
