Hubcentric Ring size. - TCCoA Forums
post #1 of 6 (permalink) Old 03-08-2004, 04:17 PM Thread Starter
94birdnj's Avatar
Hey guys.....I was just wondering what size the thunderbird hub is so that i can order some hubcentric rings. Thanks!
p.s. I found these on ebay.....says the thunderbird is 63.9. Will they work?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2464730143
-Eddie (94birdnj)
TSTaCC.com Webmaster
Tri-State Thunderbird and Cougar Club
94birdnj is offline
post #2 of 6 (permalink) Old 03-08-2004, 04:42 PM
Banned
billabong132132's Avatar
you're a soft toothed retard if you use these plastic errr I mean "poly carbonate" rings. Get some made out of T6 aluminum.
billabong132132 is offline
post #3 of 6 (permalink) Old 03-08-2004, 05:05 PM Thread Starter
94birdnj's Avatar
Ok, so after some searching it looks like our birds are indeed 63.90mm
Does anyone know of a source to get some hubcentric rims that aren't plastic (63.9 -> 73.1 mm) ? If not i'm going to have to go w/ the plastic / polycarbon one's for now 'cause they're only $15 shipped and i'm not sure where to get some custom made cheap.
-Eddie (94birdnj)
94birdnj is offline
post #4 of 6 (permalink) Old 03-08-2004, 06:58 PM
Chapter Director Coordinator
jamesD's Avatar
those will fit.. i already checked into it, but you need to make sure they fit in the center bore of your wheels...
polycarbonate isn't supposed to break.. but.. they do...
jamesD is offline
post #5 of 6 (permalink) Old 03-08-2004, 07:15 PM
Refrigerator Raider Hater
GreenBird's Avatar
billa there is no need to be harsh.
Open the yellow pages to machine shops. I bet they could crank out a set for under $50. You want a hard metal, but softer than the wheels and hub.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #6 of 6 (permalink) Old 03-09-2004, 09:41 PM
Just make sure your wheels are 73mm. You had better measure the inside of the wheel. Most Dante replica wheels for instance are 70.8mm I believe because that is what Mustangs use.
Jerry
jerrytbirdsc is offline
