Installed my 245/60/15 BFGoodwrich's today... - TCCoA Forums
post #1 of 13 (permalink) Old 03-18-2004, 12:53 PM Thread Starter
MN12 Fanatic
Tony's Avatar
Send a message via AIM to Tony Send a message via MSN to Tony Send a message via Yahoo to Tony
I mounted and balanced them at school today and found that my two driver side rims are slightly bent, ouch! So that would be were my slight vibration is coming from. The vibration is barely noticable now after balance, tie rod ends, front end alignment, valve stems lined up to yellow painted stud, new tires and torqued down to 90 ft. lbs.
So anyways, I put 35psi in the tires and they feel a little to soft and have some roll.
What psi do you guys run this size (245/60/15) at? Would it make a difference if I went up to 40psi?
They look much better than stock too, I love them! BTW I have the raised white letters showing...
Oh and does anyone use the Aggressive Handling Specs ?
I plan on doing it at school, is there any noticable difference?
Sold - 1997 Ford Thunderbird 4.6 Sport - Full bolt on, PI stuff, gears, converter, exhaust, full suspension & many other things.
2007 MUSTANG GT (5M) - 504rwhp/449rwtq
- Paxton NOVI 2200 H.O. (10psi) - CMDP's - 127200 Comp Cams - BBK LT's - O/R X - FRPP GTA's - Mid Atlantic Tuned - FRPP 4.10's - Truetrac - Moser Axles - McLeod RST - Fidanza Steel FW - Eibach Pro Kit - J&M LCA's - UMI Relo. Brackets - Spohn Adj. PHB - Prothane Motor Mounts - Hawk HPS Pads - 19" Sport Edition KV5 Rims - Hankook Ventus V12 Evo Tires
Tony is offline
post #2 of 13 (permalink) Old 03-18-2004, 01:58 PM
XR7kid's Avatar
i have 255/50 on a 7 inch rim and keep them inflated at about 45psi most the time. seems to work pretty good
XR7kid is offline
post #3 of 13 (permalink) Old 03-18-2004, 07:53 PM Thread Starter
MN12 Fanatic
Tony's Avatar
Alright, thanks for the response. After driving some more today, they definatly feel too soft at 35psi!
Tony is offline
post #4 of 13 (permalink) Old 05-07-2004, 07:16 AM
The Mach Says's Avatar
Are the 245/60's you installed on the stock 15" wheel?
If not, what width wheel are you running.
thx,
JC
'06 Black Trailblazer SS; '13 Grey GLI
Gone but not forgotten:
'03 Black Mach 1 A4 (13.7 @ 104); '03 Torch Red Mach 1 M5 (13.4 @ 106), '01 White SVT Lightning (13.4 @ 103), '78 Silver Z28, 2 Mark VIII's, 3 T-Birds, '98 Black SVT Contour #4115
The Mach Says is offline
post #5 of 13 (permalink) Old 05-07-2004, 08:10 AM
TCCoA Founder
Sir William's Avatar
Look on the side of the tire. Almost no tires today still want the old 32-35psi. The D load rated tires on my Super Duty call for 60lbs! I run them at that when I'm towing, but it's a bit harsh around town. So I air down to about 52lbs or so. Works well for me. On the car, I keep them up around 42-46 as per the ratings on the sidewall. They are great. Of course I have 255/50-17s on the car.
God Bless and Fly Low!
Sir William
TCCoA Founder
97 Thunderbird LX - Smoothed
99 Expedition Eddie Bauer
04 Grand Cherokee Overland
Sir William is offline
post #6 of 13 (permalink) Old 05-07-2004, 10:45 AM Thread Starter
MN12 Fanatic
Tony's Avatar
thx,
JC
Yeah, they are on the stock 15in. rims!
Here are a few pics:
Tony is offline
post #7 of 13 (permalink) Old 05-07-2004, 01:08 PM
mamberg's Avatar
It depends on what your goal is as to how much air pressure to run. As SW said, the recommended psi may not be optimal for all people.
If tire wear is a concern, one trick is to take a tire chalk (or any chalk for that matter) and draw a line across the tread, drive the car a few tire revolutions, and see how the chalk is wearing. If it wears off in the middle first, then lower the air pressure, if it is wearing at the edges first, increase the psi.
mamberg is offline
post #8 of 13 (permalink) Old 05-07-2004, 04:29 PM
Hate to cut in, but that is an excellent and difinitive answer to tire pressures. Just makes me want to jump out of my seat and go to it. Thanks. This should be a tech article ! Go to it. Ed
Hollywood Ed is offline
post #9 of 13 (permalink) Old 05-07-2004, 10:24 PM
Birdless
Grasshopper's Avatar
Send a message via AIM to Grasshopper Send a message via Yahoo to Grasshopper
Tony, is your bird stock height??
I'm gonna be getting into some 245/60's for my chrome fans this week hopefully...and head down to the track to burn it up.
A man may smile and bid you hail
Yet wish you to the devil;
But when a good dog wags his tail,
You know he's on the level.
--author unknown
Grasshopper is offline
post #10 of 13 (permalink) Old 05-08-2004, 08:22 AM
Johnny Bling Bling
93 lx's Avatar
i have had 245-60-15 on my car for awhile, though not bfg's. i was running 32 psi, and have wear in the middle. i believe it is because 245 is a strain on the 6.5" rims, but i like the look, so i don't care. i now have 4 new bfg 245-60-15 that will be mounted today...blackwall out(light blue car). the side of the tire states no more than 35 psi. i think i will stick to 30psi.
2009 Ford Flex Limited AWD
93 lx is offline
post #11 of 13 (permalink) Old 05-08-2004, 07:16 PM Thread Starter
MN12 Fanatic
Tony's Avatar
Yea it's stock ride height for now!
Tony is offline
post #12 of 13 (permalink) Old 05-10-2004, 08:39 AM
Exclamation
ONly problem i got is I got 01 LS rims on and you need 5/16 spacers. Teh stupid wheel weights hit the control arms only on tight lock in a hard corner barely. Btu i ahve 235/40/17 and that is the biggest Lincoln or manyufactures I have looked into recommend for the 17x7.5 rim. Maybe i am wrong I heard more can be installe dbut tires will wear unevenly. So i figure a fatter tire onthe front would NOT WORK on myc ar the rear probably after seeing the sizes yo guys have put on those stock rims. a 255/50/17 yeah woud be bad ***. I have the H&R lower spriongs so i sit a bit lower at 1 3/4 on front and back. what you guys think would be smart on a 17x7.5 rim.
Regg
PerformanceWhite 97 Tbird LX loaded
67,000 miles
4.6 v8 with motor and exhaust upgrade
Custom Interior, Exterior and Audio
wanna be racer
1972 Cutlas Supreme 55,000 miles HO 5HIT (liscence plate)
1979 Cutlas Supreme T-top Hurst/Olds Clone, 461 Olds
Hot wheels
reckmann is offline
post #13 of 13 (permalink) Old 05-10-2004, 07:26 PM
TCCoA Founder
Regg, I'd do the 245/50 or the 255/50. Both should fit just fine. The only time my tires have ever rubbed up front is turning into an off-camber driveway with the wheels turned hard. Then they rubbed lightly on the inner fender....no biggie.
Sir William
TCCoA Founder
