New Tires, What Size for 16's - TCCoA Forums
post #1 of 21 (permalink) Old 03-24-2004, 04:39 PM Thread Starter
treys92's Avatar
I've been searching for hours, but i need more answers...
I recently purchased a set of 94 SuperCoupe 16's. Well, the warm wheather is rolling around and i'm gonna have to mount some rubber on them. Right now i'm looking at stock size 225-60-16's just because of the variety and pricing, but i'd like your input on what size would look best on a car that isn't lowered. If anything, i want a wider tire with a little less sidewall, i was thinking maybe 235-55-16's. Any comments or suggestions are welcome, and if you would post pics, that would be great too.
94 SC, Black with Blue interior
MAC CAI, C&L 76mm MAF, BBK 75mm TB, MP Inlet, Raised top, ported blower, ported IC tubes, Double IC w/ 800 CFM fan, SCP downtubes, high flow cats, Magnaflow res., Flowmaster catback, solid motor & trans mounts, 190lph pump, J-modded w/ cooler and deep sump pan, 18x9 Mustang Bullets...13 sec. hopeful, awaiting Dave D. tune!
treys92 is offline
post #2 of 21 (permalink) Old 03-24-2004, 05:41 PM
fast Ed's Avatar
235-55-16 is a nice choice for the stock wheels, not too much tire for that rim width. And it's also within 1/2" of the stock diameter as well. Several of the SCCoO members here are running that size with good results.
cheers,
Ed Nicholson
SCCoO
88 T-Bird Turbo Coupe 5-speed
fast Ed is offline
post #3 of 21 (permalink) Old 03-24-2004, 07:54 PM
I put Goodyear Eagle HP 235-55-16s on my tbird about a year ago. The tire is actually about 1" wider than the 225-60-16 Eagle GTII that I took off. I really like the look.
RT
W.Cup is offline
post #4 of 21 (permalink) Old 04-08-2004, 10:58 PM
I put a set of Kuhmo 235-60-16's on mine. Got them from TireRack for $55 each.
98 4.6 SOHC, J-Modded, B & M 24K Tranny Cooler, Cold Air Intake, 76 MM MAF, RM Tube, March 1150 U/D Pullies, Poly Bushings, Air Bags, MK VIII Brakes and Wheels, Trak-Lok w/ 3.55's MK VIII Flex plate and Marauder T/C. Now that it can go, it'll be time for show.
thndrchiken is offline
post #5 of 21 (permalink) Old 04-09-2004, 11:59 PM
High-Mileage 4.6L Thrasher
Johnny Langton's Avatar
Same here..no complaints-they hook great in the dry,and hold the road well in the wet.Nice mileage so far too.
JL
Fuelly
Johnny Langton is offline
post #6 of 21 (permalink) Old 04-11-2004, 12:40 PM
Send a message via AIM to chrisnack
I'm running Potenza RE750s, in a 225/60-16. Great tire. But they are about $103/each from Tirerack.com
NSN Motorsports
http://www.nsnmotorsports.com
"Fordless" - But I do have alot of Mercon V laying around...
'96 Eagle Talon ESI
Parts ---> Dan Newman - Town & Country Ford - 800-847-2047
chrisnack is offline
post #7 of 21 (permalink) Old 04-11-2004, 01:14 PM
Jedi Master
mn12xr7's Avatar
245/45/zr16s here
wouldn't recommend these if you don't have at least 3.27s or lower gears(numerically higher)
-Orlando
mn12xr7 is offline
post #8 of 21 (permalink) Old 04-11-2004, 01:17 PM
Originally posted by mn12xr7
245/45/zr16s here
And what's the logic behind this?
JL
Fuelly
post #9 of 21 (permalink) Old 04-11-2004, 01:23 PM
Jedi Master
mn12xr7's Avatar
basically since the higher or wider the tire, the more drag it is on the car, lower gears help out
there's formula that I will post as soon as i get out of work
-Orlando
mn12xr7 is offline
post #10 of 21 (permalink) Old 04-11-2004, 01:38 PM
OK..I see where you're coming from..but here's some facts...
225/60/16:
OD-26.63"
revs/mile-757.35
245/45/16:
OD-24.68
revs/mile-817.15
That's a 7.32% difference in OD,and will make the Speedo approx 5mph off.
The thing is..the 245/45/16 is a shorter tire-so it will put less load on the engine since it effectively lowers the final drive ratio-just like installing lower gears.
In this case..it would be like going from stock 3.27's to approx 3.49.
that more than makes up for the .79" of extra width.
JL
Fuelly
post #11 of 21 (permalink) Old 04-11-2004, 02:52 PM
the perfect size for 16's imho is 245/55/16 very difficult to find but is almost of the same size as 225/60/16 but wider.
1990 5-speed BHJ balancer , ASP underdrives with march WP pulley, 5%OD, optima red top, Magnaflow resonator no cats, solid motor/tranny mounts .
turbospeed is offline
post #12 of 21 (permalink) Old 04-11-2004, 10:59 PM Thread Starter
treys92's Avatar
Actually guys, i'm thinking about goin with these. I have heard a lot of comments about 225 60's looking too small for the T-birds large wheel well. But i'm thinking of lowering the car anyway. I love this tread pattern, but let me know what you guys think, i'm still not too sure. Here's the link to the tires: http://www.tirerack.com/tires/tires....omCompare1=yes
BUT... I just found those Kumho's you guys were talking about....Lemme know which ones you prefer. Here's the link for the Kumho's : http://www.tirerack.com/tires/tires....omCompare1=yes
Thanks a lot guys.
treys92 is offline
post #13 of 21 (permalink) Old 04-12-2004, 10:53 AM
Jedi Master
mn12xr7's Avatar
tire formula
as promised, here's the formula but first let me mention that this is used to find out what the best tire diameter is (how tall is tire is, not written on street tires only on slicks and big tires for trucks) also make a note that taller tires do cause your mpgs to drop a little
I'll use an example with the formula:
tire diameter = 2 X (section width/25.4) X (aspec ratio/100) + rim diameter
so, I'll use this example
using P235/60R/15 tires and have 3.55 gears in the rear
tire diameter = 2 X (235/25.4) X (60/100) + 15
= 2 X 9.25 (rounded) X .60 + 15
= 2 X 5.55 + 15
= 26.1 inches (round down to 26)
then take the size of tires you're planning to use, let's say you want 28 inch tall tires...(use the same formula above for the tire diameter you plan to use)
now take the current tire diameter and divide by the ones you plan to use and multiply by the ratio of your rear gears....it should look like this:
26(current tires) / 28 (tires planning to put) = .92857142857
multiply .92857142857 X 3.55 = 3.2964 or 3.30
so this reduces your final drive ratio to about 3.30, a big difference and will make you car feel sluggish
now to find out what kind of gear you'll need to prevent your car from being sluggish do this:
take the tire diameter of the tires you want and divide by the current tire diameter and multiply by your final gear, like this
28/26 = 1.0769230769
1.0769230769 X 3.55 = ~3.82
So with 28 inch tires you'll need 3.82 gear, and since those aren't offered then round to the nearest, like 3.73s or 4.10s to get close to that number
hope this helps
edit: i entered "tire formula on top on the subject area so this can be found easily in the future)
-Orlando
mn12xr7 is offline
post #14 of 21 (permalink) Old 04-12-2004, 01:41 PM
These are the one's I have, they are all season, not just summer. These are H speed rated the one's your looking at are like V rated, the right ups for wet weather traction weren't to my liking.
post #15 of 21 (permalink) Old 05-07-2004, 11:37 AM
jk69cat's Avatar
not to jack, but what do you think of same question but for a lowered car?
mn12 less!
jk69cat is offline
post #16 of 21 (permalink) Old 05-07-2004, 11:44 AM
Mark M. TCCoA VP's Avatar
And if your rims can handle it what about the 245-50-16s? Some of us out here have run them for years and have been very pleased.
They are a bit much for the stock wheels.
Mark
"Mark M. TCCoA VP. Emeritus"
To the Batmobile ! ! !
ADDCO MN12 big bar R&D guru
Mark M. TCCoA VP is offline
post #17 of 21 (permalink) Old 05-07-2004, 12:24 PM
jk69cat's Avatar
yea im using stock s/c wheels. im not too thrilled with aftermarkets other than american racing . the s/c wheels are staying though i do like them.
mn12 less!
jk69cat is offline
post #18 of 21 (permalink) Old 05-08-2004, 07:57 PM
djoc2000's Avatar
255/50/16 on all 4 corners with the sc rims.....No rubbing....Looks awesome...
You can go as fast as your money will let you
djoc2000 is offline
post #19 of 21 (permalink) Old 05-08-2004, 09:54 PM
XR7kid's Avatar
XR7kid is offline
post #20 of 21 (permalink) Old 05-08-2004, 10:12 PM
miller1995's Avatar
I kinda want to try 255/55/16's on my next purchase. They are pretty close to stock size. There is a limited selection and they are all labled as sport truck tires. I don't see this as a problem and they are supposed to fit a 7" rim.
-Miller
SOLDWhite '03 Crown Vic P71
SOLD2006 Mazdaspeed6
SOLD1998 Escort ZX2
RIP My Black 95 LX 4.6
miller1995 is offline
post #21 of 21 (permalink) Old 05-09-2004, 10:04 AM
jk69cat's Avatar
cool, thanks guys, the cars getting new tires this month sometime, ill have to see what deals i can get thru work.
mn12 less!
jk69cat is offline
