255/45-18 too big? - TCCoA Forums
post #1 of 5 (permalink) Old 04-14-2004, 02:39 PM Thread Starter
Question 255/45-18 too big?
I think it will be o.k. but I'm starting to think I'll rub in frount if I lower the car. I want to keep the stock wheel hight but go wider mainly in back.
mods:
2300 stall torque converter, trans cooler, home made cat back with a hooker arrow chamber acts as a resonator too 3inch modular bent to axle and 2 1/2 modular bent too two 3 chamber flowmasters, home made ram air with k&n made with the extra exhaust
YOUNOGO is offline
post #2 of 5 (permalink) Old 04-14-2004, 03:58 PM
fast Ed's Avatar
I have that size all around on my car, mounted on 8-1/2" wheels, +35 offset. Bit of rubbing on the rear until we trimmed the fender lips.
cheers,
Ed Nicholson
SCCoO
88 T-Bird Turbo Coupe 5-speed
fast Ed is offline
post #3 of 5 (permalink) Old 04-17-2004, 06:45 PM
What about 255x45x18 with +40 offset rim on a 94SC, will they rub?
Ed, i'm sure you know why i'm asking
Cheers,
Luke
SC4LIFE is offline
post #4 of 5 (permalink) Old 04-17-2004, 09:33 PM
fast Ed's Avatar
Luke, those should be fine. On the 8" wheels, you may want to consider a 245 width tire instead though, 8" is the minimum rim width for most 255-45 tires, some brands even recommend an 8-1/2" as minimum.
cheers,
Ed N.
fast Ed is offline
post #5 of 5 (permalink) Old 04-17-2004, 10:02 PM
Thanks Ed, I'll take those notes into consideration.
Cheers,
Luke
SC4LIFE is offline
