What will fit? - TCCoA Forums
post #1 of 2 (permalink) Old 04-23-2004, 03:09 PM Thread Starter
What will fit?
Go to http://www.therangerstation.com/Metr...nch_Tires.html and follow the bouncing ball. Key in the asked for information and the program will convert the tire size in question to overall diameter, section width and section height. Start with what is stock for your ride as a reference point. Play with different sizes to find what is compatable. If the diameter is close, no changes will be necessary to your speedo. ie. a 215/70-15 is 26.9" in dia. vs a 225/65-15 which is 26.5" in dia. Close enough for government work! Hope this helps. Red
Panamah_red is offline
post #2 of 2 (permalink) Old 04-23-2004, 03:31 PM
Traveler's Avatar
Yea, there are a few sites like that. Really helpful, except I have found that just cause a particular size is exactly what you want, doesn't mean you can find that particular size!! Or at least not cheaply.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
