Spacer/Adapter Question (Sorry...) - TCCoA Forums
post #1 of 1 (permalink) Old 05-11-2004, 08:29 AM Thread Starter
Question Spacer/Adapter Question (Sorry...)
I hate to ask a spacer/adapter question, but here goes:
I have two pairs of ROH 17 x 8.5’s that I’m getting ready to install at the end of this month. But I have a “problem”: One pair has 5.740” backspacing so they are ok (I think), but the other pair has 6.290” backspacing which I think is too much. (I’ll be running 245/50-17’s on all four corners.)
My question to everyone:
Do I order a pair of 0.84” adapters (based on SC Performance 17 x 9 Cobra “R” rims with 5.950 backspacing? (I want the adapter to be as thick as possible for strength purposes.) The .84” adapter will put the outside of my 17 x 8.5 at the same outside location as the SC Performance 17 x 9.)
Or
Do I order a 0.55” spacer and space the rim out instead of the adapter?
Or
Do I order a 0.55” adapter?
Keep in mind this is temporary to make sure everything works and fits as it should. Once I know everything is ok, I’ll have the backspacing on the two rims corrected via welding to match the others.
Any suggestions/thoughts would be appreciated.
69 F100 LWB w/460 Engine
