Thought's on this wheel/tire combo - TCCoA Forums
post #1 of 9 (permalink) Old 05-11-2004, 10:41 PM Thread Starter
Oc3digital's Avatar
Send a message via AIM to Oc3digital Send a message via Yahoo to Oc3digital
This wheel in a 15x10 design. 6.5 " back spacing 5x 4.75 bolt pattern.
Plus These wheel adapters 4.25 to 4.75 1.25" thick
The 6.5 inch on the wheel - the 1.25 on the adapters will result in an effective 5.25" backspacing. only .25 off from The cobra r's on it now.
The mounted on 275/60-15 BFG Drag Radials or 275/60-15 Nitto 555
Something like this
http://www.nittotire.com/img/img_555r_3.jpg
The nitto's are 11.1 inches wide
Any reason why this wont work?
My signature--->Click Here
Oc3digital is offline
post #2 of 9 (permalink) Old 05-11-2004, 10:57 PM
96bird's Avatar
It will stick out a bit. If I was using a 10in. wide rim, then I would try to get a 7in. backspacing to make them tuck in the fender. Other than that it should be fine. Depending on your thoughts on using spacers...
Russell
96bird is offline
post #3 of 9 (permalink) Old 05-12-2004, 10:00 AM
4 Cam Bird's Avatar
A .25 inch backspace difference doesn't sound like much but it is a lot.
2011 CTS-V Wagon
4 Cam Bird is offline
post #4 of 9 (permalink) Old 05-12-2004, 11:11 AM
fast Ed's Avatar
Drag radials + wheel adapters !!
Probably not recommended.
cheers,
Ed N.
88 T-Bird Turbo Coupe 5-speed
fast Ed is offline
post #5 of 9 (permalink) Old 05-12-2004, 11:16 AM
Jedi Master
mn12xr7's Avatar
I would recommend actually doing the hub swap look here, this guys does it:
http://www.geocities.com/stus_cobra/irs_machining.html
-Orlando
mn12xr7 is offline
post #6 of 9 (permalink) Old 05-12-2004, 11:48 AM Thread Starter
Oc3digital's Avatar
Yea I checked that out earlier and that would be great except that i have rear drums and not disc, plus I can swap back to my 17' svt wheels when the nitto's/ bfg's get bad.
Thx for the response though
Kyle
post #7 of 9 (permalink) Old 05-12-2004, 12:06 PM Thread Starter
Oc3digital's Avatar
cheers,
Ed N.
Well considering the aluminum hub section of the wheel is less than 3/8" thick and the adapters are 1 ΒΌ" thick, I'm sure they would hold up. Correct backspacing would offset the additional strain being placed on the adapters. Ie. a 10 inch rim is best when it has a 5" offset. Extra camber load should be virtually nil.
My design would allow just that or close anyways 5.25"
Technically speaking the load should be transferred to the hub through the hub ring on the adapter- the hub ring on the hub- the to the suspension.
Plus this guy said it would be strong.http://www.balancemachine.com/Who_is_Fred_Goeske.asp
I'm more curious about how a 10" wheel with an 11 " tire will fit into the wheel well.
Kyle
post #8 of 9 (permalink) Old 05-12-2004, 02:49 PM
fast Ed's Avatar
If you plan on drag racing the car, I'd suggest checking the sanctioning body rules to see if wheel adapters are allowed. They may be a no-no as far as the tech officials at the track are concerned.
cheers,
Ed N.
fast Ed is offline
post #9 of 9 (permalink) Old 05-12-2004, 03:38 PM Thread Starter
Oc3digital's Avatar
If I run for money it will be in footbrake class. No tech for that.
Kyle
