Fishtailing and rear tire "chatter" - TCCoA Forums
post #1 of 9 (permalink) Old 05-27-2004, 11:32 AM Thread Starter
I know of the idiosyncrasies of our vehicles being rear-wheel drive and their behavior in the rain and slop, but mine has been started something recently that I've never experienced before. When the road is wet and I'm starting from a dead stop, the wheels feel like they slip to the point of making a chatter (instead of spinning completely, they are making intermittent contact enough to move forward slightly) on the 1-2 upshift; when it does this, I start to lose control of the rear end. I had to have the driver's side rear wheel bearing replaced a few months ago. Could the shop have messed up something? What else would cause this? It even seems to happen when I take it easy on the gas. Is this something that I just have to deal with?
Thanks!
TealBird is offline
post #2 of 9 (permalink) Old 05-27-2004, 11:39 AM
mamberg's Avatar
could be torque converter shudder????
Have you done the j-mod and or switched to Mercon V?
mamberg is offline
post #3 of 9 (permalink) Old 05-27-2004, 01:16 PM
MaleWhore
smokymance's Avatar
could even be the tires...my cars old tires wouldnt spin on the wet road under light acceleration but would slip on the white lines on the pavement....even under the slightest acceleration....thats just my case
smokymance is offline
post #4 of 9 (permalink) Old 05-27-2004, 01:28 PM
02 Explorer Pioneer
timb's Avatar
Do you have a limited slip rear? It will chatter like that with slippage
Birdless
timb is offline
post #5 of 9 (permalink) Old 05-27-2004, 03:15 PM
King Of Beers
Green95LX's Avatar
Send a message via AIM to Green95LX
it's wheel hop, your tires are losing a bit of traction in the rain
It's time to get the hell out of Dodge
A day late and a dollar short
"I never seen a T-Bird get rubber like that unless it was an SHO"
Green95LX is offline
post #6 of 9 (permalink) Old 05-27-2004, 03:56 PM
The Great Obucina's Avatar
I concur.
BTW, with the Trac Lok now, i cant bear to live without it
joseph
"Booyah". Stu Scott.
The Great Obucina is offline
post #7 of 9 (permalink) Old 05-27-2004, 05:41 PM
King Of Beers
Green95LX's Avatar
I have trac-lok and i've never had any chatter when the wheels spin. Only time i've ever had chatter was when i would turn corners. A gear oil change fixed that.
post #8 of 9 (permalink) Old 05-28-2004, 09:13 AM Thread Starter
Thanks for all of your ideas and opinions. BTW, my car does not have the limited-slip differential.
TealBird is offline
post #9 of 9 (permalink) Old 09-29-2004, 09:28 PM
Apparently I have exact the same issue after PA Super Streeter tranny install.
What's the solution? Is it inevitable for high performance trannies or I can do something about that?
98 GT Black 4R70W;
01 P&P heads (Stage1 Fox-Lake); Bullitt intake (port matched); Steeda pulleys; WMS Velocity Tube/87mm Pro-M Bullet Combo; 24lb injectors; 180 Thermostat; SCT Pro Racer Kit; Denso IT16; FMS 9mm wires; Hawker ODYSSEY PC680MJ battery; JBA headers; Magnaflow X pipe w/cats; Borla Cat Back; FMS 3.73 gear; PI Stallion 3200 (multi disk lockup); PA Super Streeter 4R70W; B&M Race tranny cooler; FRPP Aluminum Driveshaft; Metco Driveshaft Loop;
H&R Race springs; Tokico Illumina shocks/struts; MM full-length SC; MM CC plates; MM LCA; Hawk HPS brake pads; 255/45/17 Toyo Proxes T1S;
[email protected] 1.85 60' Racing weight: 3540 lbs
Andrew WOT is offline
