Question for the Wheel/Tire Gods - TCCoA Forums
post #1 of 4 (permalink) Old 12-30-2006, 02:10 PM Thread Starter
TSTaCC President
Bob Kinee's Avatar
Send a message via AIM to Bob Kinee Send a message via MSN to Bob Kinee Send a message via Yahoo to Bob Kinee Send a message via Skype™ to Bob Kinee
Alright, well i am looking at a set of 17x8 wheels for my Mark VIII with a 40MM offset. I was wondering if that offset is going to be alright being that my bird has 18x7.5s with a 40MM offset and those go pretty close to the outer lip of the wheelwell.
My next question is what is the best size tire option for that wheel. I like a lot of meat on the tire width but fear what will happen when I go too wide (especially because I have a module which lowers the car extremely low if need be). I just want to be able to cruise low but not rip off the tires on the bolts. I also need something to keep the traction when i am running, because my Michelin 225s on my factory 16s are not very grippy.
(2)93 lx 5.0s BOTH sunrise red
Double the pinkiness!
President of the Tri-State ThunderBird and Cougar Club
www.TSTaCC.com
Bob Kinee is offline
post #2 of 4 (permalink) Old 12-30-2006, 04:50 PM
fast Ed's Avatar
When you compare 2 wheel widths that have the same offset number, the difference in width will be split equally between the inside and outside. So in this case, you would have 1/4" extra on the inside, and 1/4" on the outside, compared to your 7.5" wheels.
Lots of people have 8" at +40 on MN12 and FN10 cars, that will be a good fit. As for tire size, that depends on your budget, and how close to stock diameter you want to get. 245/50/17 is a good choice, but there is limited selection in that size. 235/50/17, 235/55/17 are others that fit well. Some people go with 245/45/17, since there is a huge amount of selection available. But that size is about 1" shorter than stock, so you end up with a big fender gap on a stock ride height car.
cheers
Ed N.
88 T-Bird Turbo Coupe 5-speed
fast Ed is offline
post #3 of 4 (permalink) Old 12-31-2006, 10:03 PM Thread Starter
TSTaCC President
Bob Kinee's Avatar
How about an appropriate size for 255s?
www.TSTaCC.com
post #4 of 4 (permalink) Old 01-01-2007, 10:20 AM
fast Ed's Avatar
Some people are running 255/50/17, which is a bit taller than stock. You may end up with a bit of rubbing in the rear, if the fender lips aren't rolled or trimmed. Another choice is 255/45/17, which is just over 1/2" shorter than stock, around 26.0" diameter. Less chance of interference with that size.
cheers
Ed N.
fast Ed is offline
