how safe are adapters? - TCCoA Forums
post #1 of 11 (permalink) Old 01-01-2007, 04:56 PM Thread Starter
leet sauce
eg0r's Avatar
hey guys im trying to look into adapters for certain rims
has any1 used or can some1 comment on a safety of adapters that look like this(from experience or knowledge):
im doubting the safety of device such as that
btw i cant find any relevant posts :S
eg0r is offline
post #2 of 11 (permalink) Old 01-01-2007, 06:05 PM
MaddMartigan's Avatar
I'm sure they are safe since they are designed properly. However, good luck finding a wheel that will have the appropriate offset so that you don't have a 4x4. From everything I've seen these are for a 4x4 application where tires sticking out of the wheel well won't matter much.
Why not do a hub swap to a 5x4.5? You should have a lot more choices then.
1992 Ford Thunderbird SC
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.27 gears
Custom aluminum driveshaft
M5R2
Burned Chip for SN95 T4M0 ECM
OMGHI2U
MaddMartigan is offline
post #3 of 11 (permalink) Old 01-01-2007, 06:39 PM Thread Starter
leet sauce
eg0r's Avatar
i kinda like 4x4 look myself haha
hubswap isnt in the budget
i just found a guy whos selling the rims i love for cheap but only thing is that it needs to have thouse adapters to fit my bird. so im a little scared jumping into something i know nothing about :S
eg0r is offline
post #4 of 11 (permalink) Old 01-01-2007, 06:56 PM
I don't think you understand. The cost of those adapters is typically more than each wheel costs. They also will make your wheel stick out about 2" from the normal position.
It's not something you want to waste money on.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #5 of 11 (permalink) Old 01-01-2007, 07:38 PM
VicRattlehead's Avatar
http://i10.ebayimg.com/04/i/000/7b/ba/1694_1_b.JPG
MaddMartigan,
Originally Posted by SirWilliam
- DO NOT QUOTE IMAGES IN REPLIES
CMP Drag Racing
VicRattlehead is offline
post #6 of 11 (permalink) Old 01-01-2007, 07:58 PM
Originally Posted by VicRattlehead
MaddMartigan,
Fixed.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #7 of 11 (permalink) Old 01-01-2007, 08:01 PM
Fixed.
thank you! :P
CMP Drag Racing
post #8 of 11 (permalink) Old 01-01-2007, 08:21 PM
fast Ed's Avatar
Usually the minimum thickness for the bolt-on style spacer / adapters is 1", sometimes 1-1/4". As mentioned, most times you will end up with the wheels being pushed out past the edge of the fenders on our cars, since you need a high positive offset wheel to start with, and making it stick out another inch or more doesn't help. You won't find much choice in wheels that have enough positive offset to start with, that would still go under an MN-12 once you figure in the spacer thickness.
Bolt-on spacer / adapters are safe, as long as they are correctly torqued to the vehicle hubs, and that torque is rechecked periodically. I have a set on the front of my 68 Cougar, because the 18" wheels I chose weren't available in the correct offset in the width needed for the front of the car. They'll also give me more spoke clearance to the large brakes that are going on. Haven't had any issues with them in 5,000 miles of driving last summer.
Spacers that are hubcentric to the vehicle hub, and the wheel bore, are the best type. Eibach, H&R, and other companies sell the hubcentric spacers for some vehicles. For an MN-12, custom made adapters to 4.5" are available, but are expensive. Unless you [I]really[I] need to get a specific set of wheel on a car, it usually makes more sense to either get some wheels in the correct pattern, or go with the option of a hub swap in our case.
cheers
Ed N.
88 T-Bird Turbo Coupe 5-speed
fast Ed is offline
post #9 of 11 (permalink) Old 01-01-2007, 08:23 PM
Banned
i agree with um.....uhhh....the finger...and everyone here lol
just swap over to the 5 X 4.5 seeing how those adapters dont look too safe and yes do extend them 2" outwards changing the way the tires sit on the road. maybe if maybe you found some rims that had an offset to oversee the adapters thickness then yea it could work.
Porkchop is offline
post #10 of 11 (permalink) Old 01-01-2007, 08:35 PM Thread Starter
leet sauce
eg0r's Avatar
sry i forgot to mention that adapters come WITH rims and rubber so its a package deal for a purchaser
it sounds like the guy had it rubbing a bit in the rear but thread is about 80% remaining
thanks for into "fast Ed N" that answers my question
eg0r is offline
post #11 of 11 (permalink) Old 01-02-2007, 10:31 AM
fast Ed's Avatar
Tires have "tread", not thread ... that's what holds your clothes together.
cheers
Ed N.
fast Ed is offline
