16 inch wheel question - TCCoA Forums
post #1 of 13 (permalink) Old 01-18-2007, 05:06 PM Thread Starter
Exclamation 16 inch wheel question
Sounds like a strange question but I have purchased a set of what were called 96 to 97 wheels and have found out that they are actually the 89 to 95 wheels.
My question is will these early style wheels accept the 96 to 97 style caps with the simulated lug nuts.
park7163 is offline
post #2 of 13 (permalink) Old 01-18-2007, 05:45 PM
Awaiting E-Mail Confirmation
tinman_72's Avatar
You mean they are 92-95 SC wheels? The 96-97 Sport centercaps should fit no problem. The only difference in the wheels is that the 92-95 SC wheels have a niche to stick a tool so you can pry the centercaps off.
tinman_72 is offline
post #3 of 13 (permalink) Old 01-18-2007, 05:49 PM
So if I get 94-95 SC caps they will fit on the 96-97 sports as well?
post #4 of 13 (permalink) Old 01-18-2007, 06:41 PM
miller1995's Avatar
This is only partially correct, yes there is a notch in the 93-95 SC rims for removing the cap. The 96-97 wheels also have 5 snap features while the 93-95 SC wheels have 3 snap features. When installing the covers from the 96-97 wheels in the SC rims it will not be as secured as it should be and you risk them coming off when you hit a bump in the road. Now if he has the 89-92 wheels it will not fit at all.
Oxman- Yes you can do this it is just difficult to remove them because of the lack of a notch and the extra snap features. You can scratch your rims and break a center cap if not careful.
-Miller
SOLDWhite '03 Crown Vic P71
SOLD2006 Mazdaspeed6
SOLD1998 Escort ZX2
RIP My Black 95 LX 4.6
miller1995 is offline
post #5 of 13 (permalink) Old 01-18-2007, 06:45 PM
Traveler's Avatar
Originally Posted by park7163
...My question is will these early style wheels accept the 96 to 97 style caps with the simulated lug nuts.
Simulated Lug Nuts??
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #6 of 13 (permalink) Old 01-18-2007, 07:10 PM Thread Starter
I was not aware of the difference between the 89 to 92 and the 93 to 95.I was wondering if you could tell me which wheels I have if I e mailed you a picture.I would need your E mail address as I cannot seem to get the picture to go in the forum.
Jim
park7163 is offline
post #7 of 13 (permalink) Old 01-18-2007, 07:49 PM
My '97 7 spoke sport rims only have three "snap lock" positions and I can barely get the plasctic caps (with metal ring that snaps into the detents) off without breaking them. It would be impossible if they had used 5! they are a SOB to get off as it is.
If the other rims/caps are anything like the 7 spokes I can't imagine them flying off in a violent accident let alone daily driving....
Southpaw is offline
post #8 of 13 (permalink) Old 01-18-2007, 07:57 PM
miller1995's Avatar
93-95 SC Wheel
96/97 Sport Wheels
89-92 SC Wheels
-Miller
SOLD1998 Escort ZX2
post #9 of 13 (permalink) Old 01-18-2007, 08:10 PM Thread Starter
wheels
I got your links and I can not see the difference between the 89-92 and the 93-95.I have not recieved my wheels yet so as soon as I have got them I will check the engineering number,s on the wheels.The picture I have of the wheel has one access recess and two retaining wedges, but in the pictures that you sent they look the same.
park7163 is offline
post #10 of 13 (permalink) Old 01-18-2007, 08:13 PM
89-92 are non-directional for starters. The drivers side sweeps rearward while the passenger side sweeps forward. they are also completely different 5 spoke designs, look closely. The others are directional rims.
Southpaw is offline
post #11 of 13 (permalink) Old 01-18-2007, 08:17 PM Thread Starter
Unfortunately all I have at this point is a picture of one wheel of the set of four so it is hard to tell.
I guess I will wait till I get the set .
park7163 is offline
post #12 of 13 (permalink) Old 01-18-2007, 08:21 PM
If you look at the pictures above you can clearly see they are a different spoke design between the two. Very different. I already know whats different but I can still tell if I look at those pics above. The only thing the 89-92 & 93-95 have in common is they are both a "swept 5 spoke" wheel. Look a the shape of the spokes and how they join the hub area.
Southpaw is offline
post #13 of 13 (permalink) Old 01-18-2007, 10:18 PM Thread Starter
Yes
I copied them to my pictures and looking at them side by side I see what you meen.
I guess the set I have coming are 89 to 92.
regards
Jim
P.S. I have one spare cap for the early wheels.Has anyone got either a set or three.As you know they are stainless and are 7and 5/8th diameter.
park7163 is offline
