is 255x50x17 ok on 9 inch wide wheel? - TCCoA Forums
post #1 of 9 (permalink) Old 02-16-2007, 10:11 PM Thread Starter
just got the 03 cobra wheels 9 wide from brad and was hoping to go 255x50x17 so the wheel well gap is not so bad. the car is lowered with the ebachs but i dont really want to roll the fender lip. the car is a 97, has this been done? or should i roll the fender lip and go 275s. i'm not to good at body work so how would i do that without making the car look unprofessional? i really want a nice classy agressive stance to it. money is no object. thanks.
robbie is offline
post #2 of 9 (permalink) Old 02-16-2007, 10:20 PM
CEO, WT Club
GODSPEED's Avatar
Well, if money is no object, take it to a good body shop and have them roll/remove the fenderlip. Then you can run 275's in the rear without issues.
-Joel
Previous MN12s:
GODSPEED is offline
post #3 of 9 (permalink) Old 02-16-2007, 10:22 PM
Who is John Galt?
The Kumho site lists the width for their 255/50/17 from 7.0" to 9.0", so you should be okay.
"Won't work, can't be done"
cougar_guy04 is offline
post #4 of 9 (permalink) Old 02-17-2007, 02:42 AM
TCCoA Wheel Guru
Robbie, if money is of no concern then get a match set of 255-45-17/285-40-17 rubber and get the fenders rolled. This is a good size tire in the way of height. It will complete the look. Only thing is that its tough to find a good deal on a match set in that size combination. Choices are limited a bit if you match them in style/brand.
Rolling the fender lip is not going to change the look of the car so don't sweat that.
Brad
1990 & 1994 SC's
cudaz101 is offline
post #5 of 9 (permalink) Old 02-17-2007, 07:36 AM
Depending on the tire brand you might have to roll the fenders even with 255 50 17.
Mad1stGen is offline
post #6 of 9 (permalink) Old 02-17-2007, 09:16 AM Thread Starter
thanks for the replies, how do you roll the fenders back? the body shops and tire stores i called around here won't touch it. thanks.
robbie is offline
post #7 of 9 (permalink) Old 02-17-2007, 09:20 AM
This is what I used:
http://www.eastwoodco.com/shopping/p...&keyword=31158
Worked like a charm.
Here's my 95 (RIP) with 245 50 17's on 8.5 ROH's lowered with Eibach's and rolled fenders:
http://images.andale.com/f2/115/106/...nals_Small.JPG
My offset wasn't optimal so I had to roll the fenders.
69 F100 LWB w/460 Engine
post #8 of 9 (permalink) Old 02-17-2007, 11:18 AM
Fry Rice Specialist
Casper's Avatar
mine is 17x9 bullit with 36mm offset with 255/50/17
perfect. front have no issue and the rear only rub only when deep bump but i roll the rear fender a little bit inwards and no problem whatsoever.
how do i rolled it? just a piece of steel rod and start bending...
CarDomain Page
Casper is offline
post #9 of 9 (permalink) Old 02-17-2007, 12:54 PM
I'm running 255/50s w/ OE 17x8 Bullitts with 30mm offset and Voghtland 1" lowering springs. My shocks are adustable koni's an even on the firmest setting and with the fender lips rolled I get rubbing in front on the passenger side under high speed, high load situations. The rear is fine. I have a pair of the 05+ wheels I'm going to try on the front to see if tucking the wheels in a little helps since the rubbing is on the outside edge.
Eric Z. is offline
