looking to get a better wheel spacer wheelcentric? - TCCoA Forums
post #1 of 6 (permalink) Old 02-28-2007, 11:23 AM Thread Starter
Nick's Avatar
Did some searching, and still not sure what I need. I do know I like my current wheels, but when I put on the 13" rotors on the front, I didn't have the clearance for the calipers. I had some 5/16" universal spacers, which seem to work.
I get vibration at around 60-65mph. Looking through some old threads I came accross this site: http://www.skulte.com/product_info.p...a9026f2f4b7b29
this is the first time I have seen "wheelcentric" how does that differ from hubcentric, and should I still try and find some hubcentric rings?
Also, does anybody have other reccomendations to buy a wheel adapters from? I feel if I get something that will fit like a glove, that may resolve the vibration.
tia
Xcal2-tuned by Lonnie* Jmod kit by Darrin/Alan* '04 Marauder T/C*2002 GT MAF/airbox/intake tube* '04 explorer PI 4.6L/P&P by steenracing* Comp Cams - XE262AH* Accufab Plenum/ 75mm Throttle Body* 30lbs. injectors* 190lph fuel pump* 180* T-stat* Motorcraft 22C's* Steeda U/D pullies* JBA Ceramic Coated Headers* Aluminum Driveshaft* FRPP Aluminum pumpkin 3.73*
not installed yet:Suspension stuff: JL rstb/lower engine cradel brace/subframe connectors* KB FSTB* MN12Performance solid engine mounts/trans mount/poly crossmount bushings/IRS Diff bushings/Rear Cover Brace*RE6 Slam Specialites bags in the rear* Viair 400C compressor* 5gal Firestone tank* (8)Parker 1/2"valves* Dakota Digital Guage
Nick is offline
post #2 of 6 (permalink) Old 02-28-2007, 12:50 PM
From that link, they will bore the hub side for your hub size, and the wheel centric means they will machine a lip on the wheel side that fits the wheel hub bore.
Bangster is offline
post #3 of 6 (permalink) Old 03-01-2007, 12:55 AM Thread Starter
Nick's Avatar
So does this sound like a reasonable price? Has anybody purchased from them before?
Nick is offline
post #4 of 6 (permalink) Old 03-01-2007, 01:09 AM
The Great Obucina's Avatar
hey nick, you ever get your heads back from Steen?
"Booyah". Stu Scott.
The Great Obucina is offline
post #5 of 6 (permalink) Old 03-01-2007, 03:16 AM
TCCoA Wheel Guru
They are called Hubcentric Wheel Spacers. The have a lip that fits inside your wheels hub-bore then they are machined to the spec of the actual hub size of your car. So they have a dual purpose...They are on the expensive side but it sounds like ya need them.
Hit me up with a PM and give me the specs you need. See what I can do for ya.
Brad
1990 & 1994 SC's
cudaz101 is offline
post #6 of 6 (permalink) Old 03-01-2007, 09:58 AM Thread Starter
Nick's Avatar
Yeah, I got my steen heads. I got a garage full of parts, as you can tell from my signature. I just need to take a couple weeks, and do the PI engine swap, and tranny, etc.
Cudaz, I'll PM you,
thanks
Nick is offline
