Mickey Thompson ET Street Radials - TCCoA Forums
post #1 of 37 (permalink) Old 03-07-2007, 12:16 PM Thread Starter
I'm considering buying a pair of the MT ET Street Radials to use at the dragstrip.
Is anybody running them? How do you like them? How would you rate them relative to other drag radial tires?
MikeB
1997 Thunderbird Sport
5.0L-2V PI S/C
540 RWHP / 492 RWTQ
11.28 @ 123 MPH
MikeB is offline
post #2 of 37 (permalink) Old 03-07-2007, 07:25 PM
I ran a set of 255/50/16 MT ET DR's all last season. They hooked very well, and had surprisingly good street manners. Overall, they were a very good buy in my opinion.
-Rod
post #3 of 37 (permalink) Old 03-07-2007, 09:48 PM
CEO, WT Club
GODSPEED's Avatar
There's a pair on ebay right now in 255-50-16. They have a cosmetic blemish on them, but are pretty cheap... might be a good deal.
-Joel
Previous MN12s:
GODSPEED is offline
post #4 of 37 (permalink) Old 03-08-2007, 05:10 AM
MaddMartigan's Avatar
I'm running MT DR P275-50/15s and I've pulled a 1.77 60' on them. They seem to be a very strong tire at the track.
1992 Ford Thunderbird SC
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.27 gears
Custom aluminum driveshaft
M5R2
Burned Chip for SN95 T4M0 ECM
OMGHI2U
MaddMartigan is offline
post #5 of 37 (permalink) Old 03-08-2007, 08:12 AM Thread Starter
Guys,
Just to clarify, are you talking about the ET Streets (non-radial construction) or the ET Street Radials? I'm thinking of getting the Radials.
MikeB
5.0L-2V PI S/C
540 RWHP / 492 RWTQ
11.28 @ 123 MPH
MikeB is offline
post #6 of 37 (permalink) Old 03-08-2007, 08:17 AM
Originally Posted by MikeB View Post
Guys,
Mickey Thompson ET Street Radial is the product I have. Here it is: http://www.mickeythompsontires.com/s...ETStreetRadial
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #7 of 37 (permalink) Old 03-08-2007, 08:22 AM Thread Starter
MaddMartigan,
Yep, that is the exact tire I'm considering, although I was going to go with the 275/40-17 size. What gear ratio and differential type are you running?
MikeB
5.0L-2V PI S/C
540 RWHP / 492 RWTQ
11.28 @ 123 MPH
MikeB is offline
post #8 of 37 (permalink) Old 03-08-2007, 08:28 AM
MaddMartigan,
It's all in my signature but here is a summary:
3.73 gears - limited slip from Ford - 8.8" aluminum pumpkin
-although I turned in the 1.77 60' with 3.55 gears
I'm also running an AOD but with a 4R70W gear set.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #9 of 37 (permalink) Old 03-08-2007, 08:33 AM
My brother had BFG's, then he got the Mickeys.....there is no comparison, the Mickeys, hands down are a better gripping tire.
post #10 of 37 (permalink) Old 03-08-2007, 05:21 PM
Yep, I'm talking about the radials. I'll probably switch over to the ET Streets (bias ply slicks) this season, it just depends on how things go.
-Rod
post #11 of 37 (permalink) Old 03-08-2007, 09:55 PM
-Rod
yep about to order me some 26x8.5x15 slicks..
post #12 of 37 (permalink) Old 03-08-2007, 09:58 PM
CEO, WT Club
GODSPEED's Avatar
Are those street legal?
-Joel
Previous MN12s:
GODSPEED is offline
post #13 of 37 (permalink) Old 03-08-2007, 10:00 PM
-Joel
no....if you were asking me..
but the ones above....yes.
post #14 of 37 (permalink) Old 03-08-2007, 10:00 PM
CEO, WT Club
GODSPEED's Avatar
Asking anyone who knows, thanks!
-Joel
Previous MN12s:
GODSPEED is offline
post #15 of 37 (permalink) Old 03-08-2007, 10:06 PM
Joel,
The ET Streets and ET Street Radials are both D.O.T. legal. ET Drags are not D.O.T. legal.
-Rod
post #16 of 37 (permalink) Old 03-26-2007, 03:24 AM
What would 27X10.5-16 and read?
And can you run motorcycle tires on front skinnys?
post #17 of 37 (permalink) Old 03-26-2007, 06:00 AM
Huh?
Bad idea. Motorcycle tires can't handle the weight of our cars. I'm using a pair of 165R15 auto tires mounted on a pair of aluminum SC spares as the front skinnies.
-Rod
post #18 of 37 (permalink) Old 03-26-2007, 03:37 PM
Huh?
I went to MT.com and all the sizes read as I listed
post #19 of 37 (permalink) Old 03-26-2007, 05:06 PM
Josh, that's the size of the tire in inches. If you're asking what that would be in metric, it would be approximately 265/50/16 (rounded to the nearest 10mm).
-Rod
post #20 of 37 (permalink) Old 02-11-2008, 04:30 PM
CEO, WT Club
GODSPEED's Avatar
Joel,
-Rod
Back from the dead: Whats the difference between ET streets, and ET street radial?
-Joel
Previous MN12s:
GODSPEED is offline
post #21 of 37 (permalink) Old 02-11-2008, 04:59 PM
TGJ
Baddest N/A NPI in Canada
TGJ's Avatar
-Joel
ET Streets are Bias ply slicks with a bit of tread on them. They are D.O.T. approved but not street legal.
ET Street Radials are a Radial drag tire. They are D.O.T. approved and are street legal.
TGJ is offline
post #22 of 37 (permalink) Old 02-11-2008, 07:45 PM
Both are "street legal" aka DOT legal. The ET Streets don't really have any tread, just a few very small grooves to make them street/DOT legal. They are technically allowed on the street, but they aren't too wonderful to drive around on. The ET Street Radial on the other hand behaves nicely on the street/highway in dry weather, though the tread wears away quickly. Both tires are downright scary in the rain.
Here are pictures of the tread surfaces.
ET Streets:
ET Street Radials:
-Rod
post #23 of 37 (permalink) Old 02-11-2008, 07:47 PM
and E.T. drags...
post #24 of 37 (permalink) Old 02-11-2008, 07:58 PM
Which are not street/DOT legal.
-Rod
post #25 of 37 (permalink) Old 02-11-2008, 08:00 PM
-Rod
meh...
post #26 of 37 (permalink) Old 02-11-2008, 09:53 PM
TGJ
TGJ's Avatar
I am pretty sure that traffic laws state that a tire must have 2/32's of tread to be street legal. I know they do here in Canada. I have a set of 26-11.5-17 ET Street for my Mustang, they do not and never have had 2/32's of tread. Both of my 255/50/16 ET Street Radial have 2/32's of tread, one set barely.
TGJ is offline
post #27 of 37 (permalink) Old 02-11-2008, 10:23 PM
I haven't heard that one before. From what I can see on both the MODOT (Missouri Dept. of Transportation) and Missouri Dept. of Revenue websites, they don't make that stipulation. Either way, the little "rain grooves" in the E.T. Streets start out at approximately 7/32" when new IIRC.
I don't really count this as evidence, but Summit seems to claim that they are street legal: ET Streets
If they aren't legal, there are a lot of racers out here that aren't being bothered about it.
Sounds like a gray area to me.
-Rod
post #28 of 37 (permalink) Old 02-11-2008, 10:43 PM
ClintD's Avatar
Hey racecougar,
Those street slicks look fairly worn, I think you should buy a new pair and sell me you're old one's for a killer deal!
ClintD is offline
post #29 of 37 (permalink) Old 02-11-2008, 10:48 PM
Originally Posted by ClintD View Post
Hey racecougar,
You should have come to the SC/XR7 Shootout last year. I sold the ET Street Radials there.
And those ET Streets only have 7 passes on them. I think they have a little more life left.
-Rod
post #30 of 37 (permalink) Old 02-11-2008, 10:59 PM
ClintD's Avatar
I'm just bustin on ya, I've been trying to barrow a set ( Or buy cheep)to go to the test and tune on March 1'st with no luck.
I don't want (or have) to spend $370.00 to find out my car is a slug and be to embarrassed to go back.
LOL
ClintD is offline
