Your thoughts on putting 225/50/16 tires on my 89 - TCCoA Forums
post #1 of 6 (permalink) Old 03-22-2007, 01:13 AM Thread Starter
the89bird's Avatar
I found a good deal on a set of 4 225/50/16 tires. Is this a good size tire to use on Thunderbirds? Let me know your thoughts on this size tire.
the89bird is offline
post #2 of 6 (permalink) Old 03-22-2007, 01:54 AM
Traveler's Avatar
Why? The factory size (for supercoupes) is 225/60/16. A 225/50/16 is 24.9" in diameter while a 225/60/16 is 26.6" in diameter. a difference of 6.7%. Your speedo would be off by 4 mph at 60 (it'd read 56 while you were going 60)
If you want 225's go with the 225/60's.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #3 of 6 (permalink) Old 03-22-2007, 02:28 AM Thread Starter
the89bird's Avatar
I just found this tire calculator and see that the 225/60/16 will be almost the same size as I have on the car. Oh well, so much for my great find on the 225/50's.
post #4 of 6 (permalink) Old 03-22-2007, 10:50 AM
Traveler's Avatar
Thats the same tire calculator that I used for the information in my post.
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #5 of 6 (permalink) Old 03-22-2007, 12:42 PM
For 16's id recommend 235/60/16's. They give a little extra height to fill up the stock fenderwell and have a little bit more width too, and my speedo seems to still be dead on or at least it's close enough for government work...
Southpaw is offline
post #6 of 6 (permalink) Old 03-22-2007, 01:44 PM
Traveler's Avatar
I've got a real nice set of 255/50/16's on Ebay right now.
http://cgi.ebay.com/ebaymotors/BFGoo...QQcmdZViewItem
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
