Time for new tires. Need opinions - TCCoA Forums
post #1 of 21 (permalink) Old 04-15-2007, 11:23 AM Thread Starter
Greetings all. Its been a while.
Well, my current tires have had it. I have a leak in my rear tire (has a hole in it) so i have to fill it every day and the treat on all of them is almost bald. Its time for new ones me thinks.
Id loove to get 17" with them but dont think i can afford them (not sure how much rims and tires would cost.
I was looking at getting 225/60R-15's but the guy at the tire shop said that those might look too small, and recommended 235's instead.
I was wondering if anyone had eather size on their bird, and if so could you post a pic so i could see how they look? (or send them to me)
Work needed to be done: Heater Core Replaced; Driver Door panel replaced; Right Inner tie rod replaced; Front suspension rotting away; Wire connection to the transmission melted from contact with exhaust.
TimberWolf is offline
post #2 of 21 (permalink) Old 04-15-2007, 11:32 AM
Traveler's Avatar
First of all, read this:
http://forums.tccoa.com/showthread.php?t=56403
That having been said. Go to this link:
http://www.miata.net/garage/tirecalc.html
And you can compare tire sizes to your stock tire size all day long. And your tire guy is right, the 225/60 would be too short. My favorite tire size for the 15" wheels is 245/60/15. It is nearly identical in diameter to the stock size, and looks great on the car.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #3 of 21 (permalink) Old 04-15-2007, 11:40 AM
fl96thunderbird's Avatar
Send a message via Yahoo to fl96thunderbird
I have 235/60 r15 on stock rims. The cost difference between the 245 and 235 was too great. Didn't throw the speedo off but like 1mph at 60. Looks great IMO and I don't have to worry about the tire folding under the car on high speed corners.
SOLD the 96 in favor of a 97 ABS, TC, Sunroof
OEM E46 Bi-Xenon D3S
XBox 360 gamertag: POPIMP96
fl96thunderbird is offline
post #4 of 21 (permalink) Old 04-15-2007, 11:43 AM Thread Starter
Thats what im looking to avoid for sure. Theirs alot of sharp corner backroads where i live so good cornering is key in the tires im looking for... Got any pics?
post #5 of 21 (permalink) Old 04-15-2007, 11:54 AM
Just added them! Enjoy! They will make some squeal noises on new pavement but expect that with a heavy car.
post #6 of 21 (permalink) Old 04-15-2007, 11:57 AM
Traveler's Avatar
I put Avid 245's on my Car 2-3 years ago (This was the car before the LE, and before the Red Sport before that). I then sold the car to my sister. They have worn very well, haven't folded under, and she says she gets compliments on them all the time. And they were relatively cheap.
http://www.tirerack.com/tires/tires....e1=yes&place=0
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #7 of 21 (permalink) Old 04-15-2007, 12:43 PM Thread Starter
Those will fit on the stock rims? Will they rub on the car?
post #8 of 21 (permalink) Old 04-15-2007, 01:09 PM
Traveler's Avatar
They fit on the stock Salad Shooter wheels just fine. And they haven't rubbed once in the years that my sister has had them.
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #9 of 21 (permalink) Old 04-15-2007, 01:38 PM
jnk3846's Avatar
I would recommend the 245 also.
jnk3846 is offline
post #10 of 21 (permalink) Old 04-15-2007, 03:21 PM
I had 225/60s and I hated the way they looked, when the bird gets back on the road it's getting 255/60/15s all around.
Wes
V-sicksconv is offline
post #11 of 21 (permalink) Old 04-15-2007, 03:27 PM
Traveler's Avatar
I wouldn't go any bigger than 245/60 on the original 15" wheels. If you want to go with 255's you need to get the Sport or SuperCoupe wheels and get 255/50/16, or get a set of 17's.
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #12 of 21 (permalink) Old 04-16-2007, 12:16 AM Thread Starter
Those look pretty good, not as low profile as id like, but i guess to get the style i want, id need bigger rims :\ Which i cant afford.
Those pretty wide compared to stock tires?
post #13 of 21 (permalink) Old 04-16-2007, 12:29 AM
Traveler's Avatar
Yea they're pretty wide, and fit the fenderwells very nicely.
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #14 of 21 (permalink) Old 04-17-2007, 12:28 AM Thread Starter
Well i called discount tire and they quoted me the following..
Kelly Chargers 245/60-15 full set for $331.21
55,000 mile tire
Anyone know if they are good tires/price? I cant find them on tire rack
post #15 of 21 (permalink) Old 04-17-2007, 12:46 AM
jnk3846's Avatar
jnk3846 is offline
post #16 of 21 (permalink) Old 04-17-2007, 02:20 PM
I was thinking of going with 235/60/15 on front and 245/60/15 on back. That would be find I assume correct?
Roehm is offline
post #17 of 21 (permalink) Old 04-19-2007, 06:33 AM Thread Starter
Well, think im just going to go ahead and get the 245/60 kellys from Tire Barn. I looked at the tire yesterday and it looks decently wide, course i know that means little till its actually on the car. Well see i guess.
post #18 of 21 (permalink) Old 04-20-2007, 11:04 AM Thread Starter
Its done! Here they are, and they look alot better than the 215's thats fo sho! Oh, and they filled them with Nitrogen instead of air. Do you guys do this too? Is it really better than air?
Oh, and the guy at the place said my right inner tie rod needed to be replaced. (ill hit that in another topic)
post #19 of 21 (permalink) Old 04-20-2007, 12:16 PM
Traveler's Avatar
http://home.insightbb.com/~sylaera/i...5-60-15-03.jpg
http://home.insightbb.com/~sylaera/i...5-60-15-02.jpg
http://home.insightbb.com/~sylaera/i...5-60-15-01.jpg
That they do friend, that they do.
The Nitrogen is less likely to "seep" out than compressed air is. But when you go to check your tire pressure at a gas station you're going to use compressed air, so in the long run you're using air anyway. If the Nitrogen was free, cool. If it costs extra I wouldn't bother with it.
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #20 of 21 (permalink) Old 04-20-2007, 12:30 PM Thread Starter
I asked the guy that. He said that normally its like 5 bucks a fill, but since i bought my tires from them, and as long as they are under warranty, they will fill it free.
post #21 of 21 (permalink) Old 04-20-2007, 01:10 PM
Traveler's Avatar
Well thats great, but what happens when you're 100 miles from home and your tire is low? LOL Just add some air, and then when you get home, go to the tire shop, drain the "air" and have them fill it with Nitrogen! J/K Sounds like you got a great deal.
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
