275/45/17 - TCCoA Forums
post #1 of 5 (permalink) Old 04-25-2007, 10:57 AM Thread Starter
275/45/17
on a 7.5" wheel for drag radials...
yes or no?
If no, I assume 255/45/17 are my best choice.
Edit: Thanks
DMcBrideBoston is offline
post #2 of 5 (permalink) Old 04-25-2007, 01:07 PM
fast Ed's Avatar
Don't think anyone makes 275/45/17 in any type. I haven't seen any 255/45/17 drag radials ... they are usually 275/40/17, or a taller size, like the M&H 275/50/17.
cheers
Ed N.
88 T-Bird Turbo Coupe 5-speed
fast Ed is offline
post #3 of 5 (permalink) Old 04-25-2007, 02:20 PM
Traveler's Avatar
I think for drag radials you're better off just using a pair of cheap 15" fan blades with Drag Radials in that size. The sidewall flex of a smaller wheel actually helps launch, though it doesn't do a lot for cornering.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #4 of 5 (permalink) Old 04-26-2007, 04:43 PM
ry2lazy4u's Avatar
Send a message via AIM to ry2lazy4u
goodyear eagle f1 275/40/17, is the same height as 245/45/17
in the past (on my 2wd tbird) I had 275/40/17 on the rear and 245/45/17 on front
the wheels are 17x9
Three Birds are Better than 1! Current rides...
Red 96 LX 4.6 <----> Blue 95 LX 4.6 <----> Pearl 94 LX 4.6 (parts car!)
ry2lazy4u is offline
post #5 of 5 (permalink) Old 05-04-2007, 05:22 PM
Thunder Canary's Avatar
Send a message via AIM to Thunder Canary
i was told that you need at least a 9" wheel to support a 275 width
A nut is a nut and a bolt is a bolt. Wrench 'em off!
I used to dream about this car now I drive it- ditto
SVO Heads
SVO Intake
SHM cams
JE pistons
Eagle rods
Cobra crank
Thunder Canary is offline
