Will it work? - TCCoA Forums
post #1 of 4 (permalink) Old 05-07-2007, 03:24 PM Thread Starter
Will it work?
My 235/60/15's are toast on my car. Yokohama Avid S/T's.
I want to get 245/60/15's but they are all on back order on tire rack and summit racing.
Rather then going back to 235's I wanna give 255's a go. They are not on back order.
I'm having a hard time with choosing due to the 6.5 rim, but I'd really like to go wider.
Opinions?
razzibird is offline
post #2 of 4 (permalink) Old 05-07-2007, 03:56 PM
coggonobrien's Avatar
as long as you have enough sidewall you should be fine. i ran 275/60r15 on my fan blades for a couple years. only issue i had was premature wear in the center of the tread
coggonobrien is offline
post #3 of 4 (permalink) Old 05-07-2007, 04:01 PM
what make of tire?
and roughly, how many miles did you get out of them?
post #4 of 4 (permalink) Old 05-11-2007, 06:11 PM Thread Starter
they are on and the sidewall is a little big but they are growing on me. from the rear it looks good. front not too bad either. the upper balljoint and the tire has about 1/4 of a inch play which scares me but ijust drove it and heard no rubbing. full tilt side to side.
