i ordered some headlights off of ebay..got the clear corners on without any issues....now how do i get those damn headlights off? i have a 94 and i cant for the life of me figure out how to take the headlights out...they got these wierd clamps on those black rubber things but i got no idea how im supposed to get them out..
The metal clips need to be pulled upward. A pair of snap ring pliers helps. I believe there are 3 per headlight, it's been awhile since I've had to replace one however.
Steps:
1. Remove one clip
2. Remove next clip
3. Remove last clip
4. Disconnect wires
5. Pull housing out
:uppoint: But really, that's it. You might be able to grab the tab with pliers and pull straight up while wiggling it side to side. I think I broke 2 or 3 of those clips that way though.
I had a terrible time using snap ring pliers that were too small, It helps if you can pull the tab outward (towards the engine) as well as upward, there is a little ridge there it needs to come over.
Looks like it would be easy with the proper tools, or three small hands.
Related Threads
TCCoA Forums
1.5M posts
26.9K members
Since 2002
