wiring driving lights to turn on with headlights? - TCCoA Forums
post #1 of 7 (permalink) Old 02-25-2014, 11:43 AM Thread Starter
69ford99's Avatar
I bought some aftermarket driving lights and wanted to wire them up to turn on with headlights. Does someone have a diagram?
69ford99 is offline
post #2 of 7 (permalink) Old 02-25-2014, 01:44 PM
I used the parking light circuit to trigger the relay for them on mine.
post #3 of 7 (permalink) Old 02-25-2014, 01:46 PM Thread Starter
69ford99's Avatar
k, how do I hook that up....never really used relays instead of a rocker switch
69ford99 is offline
post #4 of 7 (permalink) Old 02-25-2014, 02:05 PM
Splice in a new wire from one of the parking light power circuits(brown wire IIRC, and the driver side inboard light is the most convenient given it's proximity to the power distribution area) and run it to terminal 85 on the relay and then run terminal 86 to ground(that will energize the coil when the lights are on). Then run a fused wire from the battery to terminal 30 on the relay, and then run a wire from terminal 87 to the driving lights, and of course run the lights to ground.
post #5 of 7 (permalink) Old 02-25-2014, 02:20 PM Thread Starter
69ford99's Avatar
sounds easy enough, thanks.
69ford99 is offline
post #6 of 7 (permalink) Old 02-25-2014, 03:59 PM
As a note - I would run the fused power to terminal 87, and terminal 30 to the lights.
The reason is, if it's a SPDT switch (the 5-terminal variant), Matt's wiring puts 12V on terminal 87a when the lights are NOT on.
Now, this may be what you want - but wiring the other way means that nothing's hot but 87 when the parking lights are off.
'Tis a minor detail, true. But "safety first, second, and third" when it comes to your battery *grins*
RalphP is online now
post #7 of 7 (permalink) Old 02-25-2014, 08:28 PM
Superduty's Avatar
I ran mine off of the head light wire instead of the parking lights. Wanted to stay street legal for the wife in our state. When high beams are on , fog/running lights are required to be off.
Superduty is offline
