89 grille replace - TCCoA Forums
post #1 of 2 (permalink) Old 03-28-2014, 12:52 PM Thread Starter
89 grille replace
Need help with how to remove the two heavy spring clamps that hold the bracket to the grille. Afraid of prying to much for fear of breaking a new bracket or the grille.
cougar428 is offline
post #2 of 2 (permalink) Old 03-28-2014, 02:32 PM
Replied to your other thread, but this forum is a better fit, so I will post again...
I was just playing around with this. There are two types of the mounts, the spring steel clamps, and bolt on. I have a broken bracket bolt on type, and a less than stellar looking spring clamp grille but with a good bracket.
first, you loosen the side bolt (it might be a screw, there are at least three variations):
then you stick a screw driver in from the front, on top of the tab, and then pull the grille off the bracket:
this is what the clamp looks like separated from the grille, the full width flat side is where you need to put the screw driver:
bottom of the tab of the grille:
top of the tab of the grille:
This is both types:
spring type bracket (and grille):
bolt on type bracket (and grille):
Bangster is offline
