Back Glass Moulding Repaint Walkthrough - TCCoA Forums
post #1 of 14 (permalink) Old 04-18-2014, 03:01 PM Thread Starter
bowez's Avatar
Well I finally decided to refinish my Back Glass Moulding--thinking I can't make it look worse.
Started with :
These are the Clips that hold the Moulding on they just slide on and off:
For stripping I use a Putty knife to remove the flacks still attached left with :
Then sanded with 80, 120, 200 and then Stoch Brite:
Be careful while sanding as the piece is aluminum so be aware of your pressure.
I did several coats 3+ ending up with :
And reinstalled:
This is paint used:
As a note Ford organically used something that was a lot more flexible (rubber like) to at this point I don't care the results speak for their-self's
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
post #2 of 14 (permalink) Old 04-18-2014, 03:17 PM
Good job And good paint.
post #3 of 14 (permalink) Old 04-18-2014, 03:22 PM
Love that paint.
post #4 of 14 (permalink) Old 04-18-2014, 03:22 PM
96dirtybird's Avatar
THANK YOU!!!!!! I so needed this. Any "walkthrough" for the repair/and or replacement of the rear upper molding? Mine has a crack/hole in it.
96dirtybird is offline
post #5 of 14 (permalink) Old 04-18-2014, 03:36 PM
Great job! If I keep mine (the car), I'll do the same thing. I've given up on finding any new mouldings anywhere.
Any idea how to take the upper one off, on both the rear and front?
1995 Thunderbird LX 4.6- 20% tint, removed air silencer and not much else! (Mustang hubs, Cobra brakes, Vogtland springs, Mark VIII LCAs, Sport shocks and more waiting to be installed)
2013 DIB GT 301A 6-speed- 15% tint, Kooks 1 7/8 mid lengths, off-road x and cat back, Barton 2-post bracket, JPC clutch line, Koni Yellows, Maximum Motorsports C/C plates, BMR K-member, A-arms, UCA & Mount, LCAs and relo brackets, Steeda Ultralites and PHB, Shaftmasters DS, Brembo wheels- Tuned by AED
Dave_6 is offline
post #6 of 14 (permalink) Old 04-18-2014, 04:08 PM
Rayo's Avatar
Turned out nice..Good Job!
1991 Ford Thunderbird Sport
Rayo is offline
post #7 of 14 (permalink) Old 04-18-2014, 06:34 PM
1996Project-bird's Avatar
I used the same paint. It lasts through rain, snow, ice, me hitting it with a scraper. Its pretty durable stuff.
1996Project-bird is offline
post #8 of 14 (permalink) Old 04-18-2014, 07:30 PM
sousa632's Avatar
Looks great. I have to do the same to the upper front/rear on mine too.
John
1996 TBird LX 4.6
2001 Sable Wagon 3.0 Duratec
sousa632 is offline
post #9 of 14 (permalink) Old 04-18-2014, 10:19 PM
Sweet stereo.
sbcaprice305 is offline
post #10 of 14 (permalink) Old 04-19-2014, 05:01 AM
bowez,
Once you remove the clips, how difficult is it to pull the molding out? Any pictures of that? I don't want to bend it!
post #11 of 14 (permalink) Old 04-19-2014, 06:10 AM
Originally Posted by Rodeo Joe View Post
bowez,
It should be loose after you pull the clips. You may have to persuade it out of the corners because its tucked under the other trim.
post #12 of 14 (permalink) Old 04-19-2014, 06:49 AM Thread Starter
bowez's Avatar
Joe,
I had to slide it back and forth (Left-Right) and then it came free. The Drivers side doesn't sit the same as before but that could be for any number of reasons. If you want to move to the Tech Articles and/or sticky this is fine by me--was the intent.
LOL, that sub (Kenwood 12") is older than the SC
One step I didn't do was Prime but I would suggest it. Before the last coat I did lightly re-scuffed the piece with Stoch Brite again, removing dust, sanding lines and debris in general. Then moved it inside for the last coat to dry.
93 SC Tbird
93 5.0 Tbird
bowez is offline
post #13 of 14 (permalink) Old 04-19-2014, 10:49 PM
I used the same paint on mine and a self etching primer first did all my window moldings and did the wiper arms at the same time molding still looks great but going to repaint the wiper arms and while I am painting I want to do my B pillar post as soon as I get done with some this side work I have now.....working on everybody else's car but mine
transtech520 is offline
post #14 of 14 (permalink) Old 04-19-2014, 11:01 PM
I might write Chung a check to do this for me this Summer ...
I've also got to get the "Trophy Scars" off of the trunk lid and rear bumper.
Great How-to! Thanks for taking the time to write this one up.
