Cougar Side Windows - TCCoA Forums
post #1 of 13 (permalink) Old 05-12-2014, 05:33 PM Thread Starter
Black_Cat's Avatar
Cougar Side Windows
Well I found my second leak point while redoing the interior of the cougar, it is the driver's side 1/4 window, the seal must have been broken a loooong while back. I already planned on replacing both windows because the outer trim is dry-rotted beyond belief. Finding the right stuff to re-seal the windows was a bear, but I think I may have finally found the closest thing to what was used at the Lorain plant. This:
http://www.autozone.com/autozone/acc...er=464397_0_0_
2011 BMW X5 35i Premium Package
2009 BMW 535i ///M Sport Package
Black_Cat is offline
post #2 of 13 (permalink) Old 05-12-2014, 05:54 PM
DO NOT USE THAT! If you urethane those windows in, they will never come out again. The stuff you want is butyl tape, and can be found at advance auto parts.
post #3 of 13 (permalink) Old 05-12-2014, 08:01 PM Thread Starter
Black_Cat's Avatar
Butyl tape seems to be tough and not very pliable. Whenever I pull cougar 1/4 windows off it's like this sticky stringy black paste that seems to have sealed the windows up from the factory, doesn't seem like butyl tape. I'm confused.
post #4 of 13 (permalink) Old 05-12-2014, 08:13 PM
ClintD's Avatar
the sticky gooey stringy stuff is butyl tape.
ClintD is offline
post #5 of 13 (permalink) Old 05-12-2014, 09:07 PM Thread Starter
Black_Cat's Avatar
Yeah so I see, took a look in the service manual, anyone know the interchange # for PN: 29904?
I noticed it's foam core butyl tape, that would explain why normal butyl is so resistant to being compressed, the foam compresses and expands and the butyl covering seals everything up.
Still wondering if it's worth using the urethane since I rarely plan on removing the glass again lol.
Update: Found this on sccoa - http://www.sccoa.com/forums/showthre...placing+window
post #6 of 13 (permalink) Old 05-16-2014, 12:27 PM Thread Starter
Black_Cat's Avatar
Well I found the butyl tape that ford used on our quarter windows, it's still available.
It's a foam core butyl tape, not sure on the diameter yet, I'll measure it later, but the ford part number is:
E69Z-19562-A
Even JEGS has it.
http://www.jegs.com/i/ACDelco-Motorc...9562A/10002/-1
post #7 of 13 (permalink) Old 05-16-2014, 02:03 PM
Is that tape the same stuff used to hold the windshield in? Mine is leaking and has a lot of wind noise at freeway speeds.
1995 Thunderbird LX 4.6- 20% tint, removed air silencer and not much else! (Mustang hubs, Cobra brakes, Vogtland springs, Mark VIII LCAs, Sport shocks and more waiting to be installed)
2013 DIB GT 301A 6-speed- 15% tint, Kooks 1 7/8 mid lengths, off-road x and cat back, Barton 2-post bracket, JPC clutch line, Koni Yellows, Maximum Motorsports C/C plates, BMR K-member, A-arms, UCA & Mount, LCAs and relo brackets, Steeda Ultralites and PHB, Shaftmasters DS, Brembo wheels- Tuned by AED
Dave_6 is offline
post #8 of 13 (permalink) Old 05-16-2014, 04:44 PM Thread Starter
Black_Cat's Avatar
Noooooooo! If you used butyl tape for your windshield it wouldn't be there very long lol. You need a urethane sealant like 3M Window-Weld that comes in a tube, that is what is used for the windshield and rear window
post #9 of 13 (permalink) Old 05-16-2014, 08:14 PM
Ah ok! I was just wondering as I was thinking it was a type of urethane sealant.
Dave_6 is offline
post #10 of 13 (permalink) Old 05-25-2014, 08:19 AM
1995 cougar xr7's Avatar
So how did these windows turn out. The moulding around my windows look like crap. I sanded them and painted them. But they are pitted so bad. I would like to see some pics of your new windows.
1995 cougar xr7 is offline
post #11 of 13 (permalink) Old 05-25-2014, 09:53 AM
ClintD's Avatar
windshields used to be held in with butyl tape, actually almost everything from the early 80's and down was either a rubber gasket or butyl tape.
Now the only thing I use butyl tape for is to remove a pilot bearing!
ClintD is offline
post #12 of 13 (permalink) Old 05-25-2014, 02:31 PM
You can always tell by 70s cop movies/TV shows they used butyl tape, whenever the windshield was too cracked and bullet riddled to see out of the sidekick would always effortlessly kick out the whole windshield with his foot
post #13 of 13 (permalink) Old 05-26-2014, 12:55 AM Thread Starter
Black_Cat's Avatar
The windows turned out real well, much better than my originals, no leaks at all now, ill get pics soon.
