Front end body work swap - TCCoA Forums
post #1 of 7 (permalink) Old 10-02-2014, 06:26 PM Thread Starter
r429460's Avatar
I need to change hood, headlights and bumper cover on my 95 cougar to
1996 parts.
The question, is this a direct bolt on swap or are there any hidden parts that I don't
know about?
I need the additional room for the reverse mounting of the alternator,
due to the TFS intake that's on the engine now.
Quickest N/A Modular MN12.
01/31/18 PBIR
THE danner EATER
r429460 is offline
post #2 of 7 (permalink) Old 10-02-2014, 07:23 PM
It is all a direct bolt-on swap. Just make sure you also have the 96/97 secondary latch release too, cause it is different from 95 to 96, and your old one won't work with the newer header panel. Before you go doing all that though, why not just get a mach1 hood for it?
post #3 of 7 (permalink) Old 10-02-2014, 07:40 PM
96PRLBRD's Avatar
As an aside, I don't know if you have the parts right now but I have a pair of OEM corner lights for sale off my '96.
--> My most recent pics <--
96PRLBRD is offline
post #4 of 7 (permalink) Old 10-02-2014, 08:11 PM
Boo! 96s are ugly! I second mikey, other option would be getting a 89-93 Tbird cowl hood and lopping off the lip.
post #5 of 7 (permalink) Old 10-03-2014, 08:02 AM Thread Starter
r429460's Avatar
Thanks, I just needed to be sure.
01/31/18 PBIR
THE danner EATER
r429460 is offline
post #6 of 7 (permalink) Old 10-05-2014, 09:01 PM
pendejo
druggles85's Avatar
Or leave the lip and swap on a SC front bumper, maybe stick a cougar emblem on there somewhere so people don't get confused, still look better than the 96 front...
"Yesterday, upon the stair,
I met a man who wasn't there.
He wasn't there again today,
I wish, I wish he'd go away..."
druggles85 is offline
post #7 of 7 (permalink) Old 10-06-2014, 05:26 AM
Or shim the k-member down. Or custom motor mounts to drop the motor down a little bit. Or shim the fenders and hood up. Or a combination of several of those things.
