94 tbird bumper markers - TCCoA Forums
post #1 of 6 (permalink) Old 01-28-2015, 10:29 PM Thread Starter
Hey everyone, I own a 94 tbird Lx V8, I want to install the bumper lights that come on when the blinker is on. I think there from a 89-83. Is this possible and how. Thanks...
Also, My mirrors and roof lights stopped working. I checked the fuses and there good. Anyone know why this is happening...
94_tbird is offline
post #2 of 6 (permalink) Old 01-28-2015, 10:51 PM
If you look inside your bumper cover there's markings molded into it telling where to cut and drill the holes for the lights, for some reason Ford kept those even after the option was dropped.
As for the wiring, you'll have to add it between the switch and lights since it's not prewired. the multifunction switch has two unused spaces in the connector going plugged into it, and these are for cornering lights(left/right) so if you can find a doner connector pigtail to pull the individual pins out and plug them into your connector you're good to go. It's up to you how you want to run them up front, easy way is run them through a grommet directly or open up the wiring harnesses(dash and engine compartment) and tuck them neatly inside with the inline terminals added.
post #3 of 6 (permalink) Old 01-29-2015, 03:32 AM
Moved to Exterior.
post #4 of 6 (permalink) Old 01-29-2015, 06:55 AM
One thing Matt forgot to mention was that you'll also have to change the multi function switch to supply the signal. This isn't a problem - the cornering lights were an option on the Crown Vic, and the non-cornering MFS was the same on the Crown Vic and the Tbird/Cougar, so ...
Fuelly
RalphP is online now
post #5 of 6 (permalink) Old 01-29-2015, 03:11 PM
That's not true Ralph, the MFS is exactly the same, cornering lamps or not(at least the 94-97 ones). The cornering light terminals are just left unused.
post #6 of 6 (permalink) Old 01-30-2015, 06:51 AM
Is it?
I remembered that the CV had two different ones.
My bad.
Fuelly
