Trouble with Sentinel Lights - TCCoA Forums
post #1 of 12 (permalink) Old 09-21-2015, 02:21 PM Thread Starter
My Sentinel Lights stay on in broad daylight. Can someone tell me if this means the photo cell is bad and if so what is the name of that part and a source? I have a 1995 T-Bird.
Thanks in advance,
Chapman
Chapman is offline
post #2 of 12 (permalink) Old 09-21-2015, 02:52 PM
Thanks in advance,
Chapman
I would just turn it off
steveg1988 is offline
post #3 of 12 (permalink) Old 09-21-2015, 03:41 PM
SuperThunderbirdLX's Avatar
Yuck. Don't use them nasty GM words on our cars
They're called autolamps on Ford vehicles. They don't need no fancy name, just name it what it does.
Photo cell might be bad, idk how to diagnose it. Just shut them off by moving the dial until it clicks. I believe you move it down.
-Daniel
SuperThunderbirdLX is offline
post #4 of 12 (permalink) Old 09-21-2015, 04:04 PM Thread Starter
Does anyone have a source and part number for the photo cell as it does not come up in Ford Parts?
Thanks in Advance,
Chapman
Chapman is offline
post #5 of 12 (permalink) Old 09-21-2015, 04:59 PM
Boneyard source.
Fuelly
RalphP is offline
post #6 of 12 (permalink) Old 09-21-2015, 05:29 PM Thread Starter
Originally Posted by RalphP View Post
Boneyard source.
What is the Boneyard Source?
Chapman is offline
post #7 of 12 (permalink) Old 09-21-2015, 07:27 PM
Rayo's Avatar
AutoLamp Sensor Adjustment
Your AutoLamp Sensor is probably fine..Maybe a little dirty, but probably fine..
Before I would go through the trouble of removing it from the dash..I would take a q-tip with some alcohol on it, and clean the "eye"..
It's probably covered in dust, and who knows what else..Therefore it thinks it's night outside, and keeping your lights on all the time..
After you've cleaned the "eye" of the sensor..If you find your lights still remain on during the day with AutoLamps turned on..
There is an adjustment you can make..
You have to remove the AutoLamp Sensor in order to make any adjustments to it though..
It's held down by 2 screws underneath the dash bezel on the passenger side of the dash..
You can see in this pic how the adjustment works:
It can be turned either way with a small screwdriver..
Now there is that rare chance you need to replace the AutoLamp Sensor because it doesn't work..
The bad news is the actual AutoLamp Sensor is obsolete, and is not available aftermarket..
The Ford Part Number for it is: (F4LY-13A018-A) or (F4LY13A018A)
You can find a used one in any 94-96 Lincoln Mark VIII..As well as any 94-97 Thunderbird/Cougar that came equipped with AutoLamps..
Have fun!
1991 Ford Thunderbird Sport
Rayo is offline
post #8 of 12 (permalink) Old 09-21-2015, 07:40 PM Thread Starter
It's held down by 2 screws underneath the dash bezel on the drivers side of the dash..
Have fun!
Thanks Rayo. I greatly appreciate the information. I will give it a go.
Thanks again,
Chapman
Chapman is offline
post #9 of 12 (permalink) Old 09-21-2015, 07:52 PM
Rayo's Avatar
De nada..
Rayo is offline
post #10 of 12 (permalink) Old 09-21-2015, 08:07 PM
I don't have experience with the sensor adjustment - but it's most definitely on the passenger side (at least on the gen 2).
post #11 of 12 (permalink) Old 09-22-2015, 06:55 AM
Rayo's Avatar
Good catch Brandon..
On the 89-93 MN12 the AutoLamp Sensor is located on the top of the drivers side of the dash..Under the defrost grille..
It looks like they moved the AutoLamp Sensor to the passengers side of the dash on the 94-97 MN12..
Rayo is offline
post #12 of 12 (permalink) Old 09-22-2015, 09:56 AM Thread Starter
Thanks Everyone..
Chapman
Chapman is offline
