Sylvana zXe bulbs - TCCoA Forums
post #1 of 10 (permalink) Old 01-06-2016, 07:45 AM Thread Starter
Tweety Bird's Avatar
Arrow Sylvana zXe bulbs
I put a set of these in my '95 LX 40th anniversary the other day. Like I said put them in during the day.
It snowed the night I put them in and haven't/won't take the car out in this mess.
Anyone have them? Like/dislike them? Comments on them?
NOBODY ever tells a story where they look bad !!!
Tweety Bird is offline
post #2 of 10 (permalink) Old 01-06-2016, 09:11 AM
96beaterbird's Avatar
Waste of money and little to no difference imo.
A relay harness to reduce voltage drop to the headlights will make a way bigger difference for not much more $.
96beaterbird is offline
post #3 of 10 (permalink) Old 01-06-2016, 01:33 PM
DisturbedBird's Avatar
I put them in my car and noticed a difference but the big difference was when I change the headlights themselves. With the old cloudy lenses you won't notice it too much but with new ones it's a big change in my opinion.
DisturbedBird is offline
post #4 of 10 (permalink) Old 01-06-2016, 06:21 PM Thread Starter
Well, my car is a garage queen. The lens are pretty dern clear, and I got the bulbs, c-h-e-a-p !!
post #5 of 10 (permalink) Old 01-06-2016, 06:48 PM
Cheap is good for sure! You should see a noticeable difference.
post #6 of 10 (permalink) Old 01-06-2016, 10:24 PM
Add the relay harness, and you'll be blazing white *grins*
I like the ones in my Dakota.
I'm running HIRs in my Cougar (with the GM headlamps).
Fuelly
RalphP is offline
post #7 of 10 (permalink) Old 01-08-2016, 04:41 PM
MerkCougar's Avatar
Is a relay harness a generic term? Or is there something specific I need to ask for? Because me myself am pretty dissatisfied about the brightness (or lack there of) from hour headlights
MerkCougar is offline
post #8 of 10 (permalink) Old 01-08-2016, 07:52 PM
It's a generic term.
A SPECIFIC one, for the 89-90 Cougars is such as this one: https://www.painlessperformance.com/webcat/30817
For 1990+ Cougars, you could also use this one: https://www.painlessperformance.com/webcat/30816
That's just one example, BTW. There's several others, and since I grew up with a hot soldering iron in my hand I made my own from 12GA wire by chopping up a couple of 9005/9006 pigtails, adding a 9007 female, and did that while converting to GM headlights so I got quad beams out of the deal also.
Very telling is that my passenger headlight picked up over a volt ...
(Yes, I fused it also. Two separate fuses, so if I lose one headlight I can keep on with the other set ... )
Fuelly
RalphP is offline
post #9 of 10 (permalink) Old 02-19-2016, 01:26 AM
Thread is a bit old but zXe's are just another marketing disappointment really. Sure they are whiter in color, but actual road luminosity isn't really any better. Generally speaking, stay away from bulbs that have any type of color tint on the glass. Doesn't matter what lights you get though, the limitation is the assembly itself. The beam pattern is just horrible no matter what you do.
1996 Ford Thunderbird LX - 4.6L V8 - Full LED conversion almost complete - Daily Driver
2012 Mazda 3i Touring - Skyactiv-G 2.0L I4 - LED interior and tag lights, TRS Black Series Clear Lenses w/blocked squirrell finders, DDM 4500K HID low beams, 9011 HIR1 high beams - SOLD
2011 Mazda 2 Sport - 1.5L I4 - LED interior and tag lights, First Retrofitted Mazda 2 in North America using Morimoto Mini D2S projectors and Osram Xenarc 4300K D2S bulbs http://www.mazdas247.com/forum/showt...it-your-Mazda2 - TOTALED
Now offering retrofitting services including projector swaps, lens swaps, painting, etc. PM for details
96MN12Bird is offline
post #10 of 10 (permalink) Old 03-04-2016, 09:57 PM
MerkCougar's Avatar
By assembly you mean how our cars lights pretty much only light up the first 10 feet in front of our car?
Ralph P. I'm curious to see how you did that because I'm about to pick up a solder set as soon as one shows up in front of me. .
