Any aftermarket headlights for 94 mn12? - TCCoA Forums
 16Likes
  • 3 Post By V8ThunderCat
  • 1 Post By XR7-4.6
  • 1 Post By V8ThunderCat
  • 2 Post By CDsDontBurn
  • 1 Post By XR7-4.6
  • 2 Post By Woodman
  • 2 Post By XR7-4.6
  • 1 Post By Beerdog80
post #1 of 28 (permalink) Old 03-16-2016, 02:14 PM Thread Starter
Slow94lx's Avatar
I have been looking for some new headlights. I havent seen any aftermarket headlights if anyone has seen some or bought some pls let me know thx.
Slow94lx is offline
post #2 of 28 (permalink) Old 03-16-2016, 03:20 PM
Woodman's Avatar
The only aftermarket headlights I've seen are stock styled EagleEye headlights, easily found on Ebay.
IF you want a real upgrade, one of our members did a very good write up of installing HID projectors into the stock housings.
http://forums.tccoa.com/15-exterior/...-write-up.html
Woodman is offline
post #3 of 28 (permalink) Old 03-16-2016, 07:32 PM
Did you mean for a 1994 Thunderbird, or a 1994 Cougar?
The headlights are different - and I've got some non-Cougar headlights in my 1991 (which Cougar used the same headlights 1991-1995.)
Fuelly
RalphP is online now
post #4 of 28 (permalink) Old 03-16-2016, 09:19 PM
V8ThunderCat's Avatar
Based on his other topics it looks like he has a 94 Bird.
The consensus I've seen says that they are too small for projectors. Then again I still need to find out the length and width of projectors and compare them to my Cougar's headlights and Grand Marquis' headlights before I go too far with my project. It's too bad nobody makes aftermarket headlights for our cars but it does feel good when you make it happen yourself. A good option for you Slow is to upgrade to the 96/7 style and add the projectors. I think the width of the projectors is where the pre-96 headlights have a problem but when there's a will there's a way.
-Randy-
V8ThunderCat is offline
post #5 of 28 (permalink) Old 03-16-2016, 09:34 PM
The problem with projectors on pre 96s is the fluted lens, 96-97s (and grand marquis conversions) are clear. Size wise the older housings would likely be even more accomidating, but putting a projector behind a fluted lens would completely defeat the purpose, you may as well use a crappy drop in HID kit.
V8ThunderCat likes this.
post #6 of 28 (permalink) Old 03-16-2016, 11:48 PM
Cobra_Bird's Avatar
Just to chime in my 2 pennies, I just did the Eagle Eyes on my 95 tbird with bi-xenon hid's. They look awesome at night, pic in my garage.(as soon as I upload them, sorry)
No one flashing me due to blinding. Wide, bright white (5k) light.
Highly recommend the upgrade.
Mark
Semper Fi til I die.
Cobra_Bird is offline
post #7 of 28 (permalink) Old 03-22-2016, 09:38 AM
Beerdog80's Avatar
Did you do the projectors as well?
Beerdog80 is offline
post #8 of 28 (permalink) Old 03-22-2016, 11:23 AM
Woodman's Avatar
Because he mentioned no one flashing him, I would say no he didn't.
Woodman is offline
post #9 of 28 (permalink) Old 03-22-2016, 05:20 PM
I didn't see any pics of his lights in his garage.
Woodman likes this.
-Randy-
post #10 of 28 (permalink) Old 03-22-2016, 06:05 PM
CDsDontBurn's Avatar
Your headlights aren't shown on your Garage. Did you upload them?
V8ThunderCat and Woodman like this.
CDsDontBurn is offline
post #11 of 28 (permalink) Old 03-22-2016, 07:23 PM
With the fluted lenses?
-Randy-
post #12 of 28 (permalink) Old 04-01-2016, 01:52 PM
Beerdog80's Avatar
If I went with the 96/97 headlights in my 95, do I need to swap the hood as well?
post #13 of 28 (permalink) Old 04-01-2016, 02:10 PM
Need to no, but it will look better
Woodman likes this.
post #14 of 28 (permalink) Old 04-01-2016, 03:39 PM
Woodman's Avatar
The only stuff you HAVE to swap is the header panel behind the front bumper cover so that the lights will actually install. But if you leave the 94/95 hood you'll have "eyelashes" above the headlights where they don't quite line up to the hood.
Woodman is offline
post #15 of 28 (permalink) Old 04-02-2016, 07:42 AM
Send a message via AIM to Red97Tbird
Has any one tried the led bulbs in our cars? They run 120 for a good set and there just plug and play. There a crap load brighter then stock.
Red97Tbird is offline
post #16 of 28 (permalink) Old 04-02-2016, 08:08 AM
Woodman's Avatar
Quality light is NOT as much about brightness as it is how it is projected down the road. The headlights in our cars do not project well, you can put the brightest style of light in there, and it will still not light up as well as a decent projector retrofit.
LED bulbs also have design issues, they aren't like an incandescent bulb that has it's light created by the filament, or an HID that has it's light created at the arc, but by a diode or series of diodes that are extremely directional. They won't bounce off the reflectors in our lenses as well as an incandescent will, and even the "plug and play" HID lights give a scattered, wide, unfocused light pattern.
You can do a few things to mitigate that dispersal, such as aim them down to not blind oncoming drivers, but that's going to severely limit your visibility as well by having a very bright point close to the front end of the car, and not further down the road where you need to see.
The only things we can do to get better light are A) Get the best incandescent bulbs you can get, make sure your lenses are clean and not yellowed/hazy, and aim them properly so they focus down the road or B) install some good projectors, make sure you're not hazy, and aim them properly.
A good projector does an excellent job with focusing the light and cutting it off so there is no bleed over.
I am of the opinion that the reason most don't flash you when you're driving down the road with "plug n play" HID's is because people just don't realize they are supposed to anymore. I very rarely get the courteous little flash to say (there's something up ahead like a police car or some deer, be careful) and people look at me confused when I do it. Older folks, guys on motorcycles, and people who actually enjoy driving tip me a wave when I do it, but even at night if I flash someone who's high beams are on, they just don't get it.
V8ThunderCat and RalphP like this.
Woodman is offline
post #17 of 28 (permalink) Old 04-02-2016, 10:59 AM
Woodman's Avatar
This is an EXCELLENT comparison of Halogen vs HID vs LED in a factory projector housing in a Mazda 3.
I know a halogen projector isn't ideal for HID or LED lightbulbs, but it shows the clear difference between the three. To my eye, the HID does the best job in this comparison.
Here's a good side by side comparison of a drop in HID kit in a regular halogen housing.
Notice all the light bleed over. For HID and LED, projectors are the way to go.
Woodman is offline
post #18 of 28 (permalink) Old 04-02-2016, 12:26 PM
Maybe it's that my car is too low and the entire new car buying public has jumped on the tall CUV bandwagon but even factory projectors on those blind me now, I think everyone is just used to driving in the evening sucking. I flashed my lights at someone a month ago, then they flashed back their high beams I thought they already had on!
post #19 of 28 (permalink) Old 04-02-2016, 12:35 PM
Woodman's Avatar
Yeah, mine is very low too. I don't worry about the regular lights hitting me, I just focus more toward the right side of my lane in that case, but I notice very very few people have their lights aimed well too. Seems to be a lost art.
Woodman is offline
post #20 of 28 (permalink) Old 04-04-2016, 08:37 PM
Beerdog80's Avatar
I agree. Aim your shit!
Woodman likes this.
post #21 of 28 (permalink) Old 04-04-2016, 08:39 PM
Beerdog80's Avatar
Woodman likes this.
post #22 of 28 (permalink) Old 04-04-2016, 08:58 PM
Woodman's Avatar
Damn, are those lightsabers or something? They LOOK GOOD!
Woodman is offline
post #23 of 28 (permalink) Old 04-04-2016, 09:11 PM
Beerdog80's Avatar
Might as well be. They do the job very well in the pitch black Oklahoma night.
But they are 5k HID's.
Woodman likes this.
post #24 of 28 (permalink) Old 04-04-2016, 09:17 PM
Woodman's Avatar
Yeah, I am definitely doing HID projectors in my 97 asap.
Woodman is offline
post #25 of 28 (permalink) Old 04-04-2016, 09:19 PM
Beerdog80's Avatar
Smart move. You won't be disappointed.
This is my lightning post HID retrofit.
Woodman likes this.
post #26 of 28 (permalink) Old 04-04-2016, 11:10 PM
Cobra_Bird's Avatar
No, no projector swap just the Eagle Eyes & 5k bixenons.
Mark
post #27 of 28 (permalink) Old 04-05-2016, 07:13 AM
coggonobrien's Avatar
beerdog, you have info on your setup?
coggonobrien is offline
post #28 of 28 (permalink) Old 04-05-2016, 09:19 AM
Beerdog80's Avatar
Morimoto Mini H1's, their 5k HID kit.
