So I was adjusting my headlights... - TCCoA Forums
 1Likes
  • 1 Post By miller1995
post #1 of 14 (permalink) Old 05-03-2016, 09:45 PM Thread Starter
Woodman's Avatar
I was trying to adjust my headlights today, and noticed the driver side was just flopping around. I pulled it out using a 9mm socket on the retainers and the adjuster for the up/down (the inner most adjuster) as well as the retainer directly above it were not in the adjuster base anymore. See pic...
So I took those two torx screws out, and tried to re-insert them into the adjuster, no luck.
So I'm assuming the adjuster is broken? Is this something I can replace at the auto parts store, or do I need to pull ones off a headlight at the junkyard (assuming I can find a good one)?
Or is it time for a new headlight assembly? They're not foggy/scratched up. I'd like to keep them if I can.
Woodman is offline
post #2 of 14 (permalink) Old 05-21-2016, 10:19 PM
TBird94's Avatar
This looks different than the adjusters on my '94 T-Bird.
Auveco makes/sells automotive clips, screws, connectors, headlight adjusters, etc. Their catalog has thousands of products. If you don't have a part number, finding the part you need can be a challenge.
Disclaimer: I have no financial interest in Auveco or the other company links provided.
Good luck, man. Finding small parts can be a real PITA.
https://www.auveco.com/default.aspx
ClipsAndFasteners.com - Automotive Retainers,Clips and Fasteners
Northland Fasteners- Best selection of Automotive Fasteners - 816 453 7277
TBird94 is offline
post #3 of 14 (permalink) Old 05-21-2016, 11:12 PM Thread Starter
Woodman's Avatar
That's because mine is a 97. Different headlight design, different adjusters.
I'll check it out. I was on the way to the salvage yard to see if I could scrounge some, but that was the day my oil line decided to let go.
Woodman is offline
post #4 of 14 (permalink) Old 05-22-2016, 05:50 AM
miller1995's Avatar
I think I have a few spares. I'll check when I get home tonight.
Woodman likes this.
SOLDWhite '03 Crown Vic P71
SOLD2006 Mazdaspeed6
SOLD1998 Escort ZX2
RIP My Black 95 LX 4.6
miller1995 is offline
post #5 of 14 (permalink) Old 05-22-2016, 08:54 AM Thread Starter
Woodman's Avatar
Thank you! Give me a heads up.
Woodman is offline
post #6 of 14 (permalink) Old 05-22-2016, 08:49 PM
miller1995's Avatar
Here's what I've got:
SOLD1998 Escort ZX2
post #7 of 14 (permalink) Old 05-22-2016, 10:17 PM Thread Starter
Woodman's Avatar
I could use them, how much would you like for them?
Woodman is offline
post #8 of 14 (permalink) Old 05-23-2016, 01:20 PM
miller1995's Avatar
Which parts do you want? There are more than a couple lights worth here.
SOLD1998 Escort ZX2
post #9 of 14 (permalink) Old 05-23-2016, 02:24 PM Thread Starter
Woodman's Avatar
Two of the longish ones with an adjuster and a secure post in them please.
Woodman is offline
post #10 of 14 (permalink) Old 05-23-2016, 08:42 PM
miller1995's Avatar
How about $17 shipped by USPS?
SOLD1998 Escort ZX2
post #11 of 14 (permalink) Old 05-23-2016, 09:44 PM Thread Starter
Woodman's Avatar
Sold American!
Sent you $20 to cover any paypal fees.
Woodman is offline
post #12 of 14 (permalink) Old 05-27-2016, 11:49 PM Thread Starter
Woodman's Avatar
Received the adjusters today, thank you very much!
Woodman is offline
post #13 of 14 (permalink) Old 06-02-2016, 08:49 PM
miller1995's Avatar
Glad I could help.
SOLD1998 Escort ZX2
post #14 of 14 (permalink) Old 06-02-2016, 08:52 PM Thread Starter
Woodman's Avatar
Glad I could help.
If you have a spare motor floating around, I could use one!
Thanks again, at least my lights are aligned now.
Woodman is offline
