To those with the t-bird mud flaps - TCCoA Forums
 1Likes
  • 1 Post By Trunk Monkey
post #1 of 2 (permalink) Old 06-03-2016, 09:26 PM Thread Starter
KULLER94's Avatar
Did you have to drill holes in the front fender to mount them up? I bought a set today and the rear ones bolted up fine with 3 screws, but im noticing that theres only one screw on the front fenders.
KULLER94 is offline
post #2 of 2 (permalink) Old 06-03-2016, 09:41 PM
Yes, you'll need to drill the front. If I recall, you should be able to drill the plastic splash guard and not the sheet metal of the front quarter panel. Also, if you have OEM front mudflaps be sure to line the dimple in the mudflap up with the dimple in the rocker panel at the bottom for a perfect fit.
KULLER94 likes this.
